I had an outside plastic pipe water supply line replaced after the fence people cut thru the original. This line supplies 3 areas and worked perfectly prior to replacement., equal pressure to all 3 areas It services two hoses, one within feet of the hookup, the other appx 60+= feet away at the other side of the home, and the third is to a water line on my boat dock also appx 60 feet away.
Since the replacement, I have about 90% pressure at the closest hose, and just a weak amount of water to the furthest hose and boat dock....both of which are used 5 times MORE than the closest hose. Water barely shoots out 4-5 feet at the far hose and dock........it will shoot across the 30 foot pool on the near hose and the hose looks like a fire hose out of control if not careful.
How do I regulate this pressure to be equal again to all 3 areas?
