Regen coloring
Discussion in 'Water Softener Forum, Questions and Answers' started by moreira85, Dec 25, 2013.
  1. moreira85
    moreira85 New Member
    Nov 5, 2013
    Massachusetts
    I have a well water with 3ppm of iron. I installed a fleck 5600sxt and what a difference it's made. Crystal clear water and no staining in toilets. I have it set to regen every 7 days. I notice every time it regenerates the morning I wake up the water is discolored yellowish until I run the faucet for 3-4 mins then it clears up any thoughts?
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Regen or backwash? My guess is that while it is backwashing, that water is being used, perhaps several sources... R/O filter, icemaker, humidifier, leaking toilet, etc. and so raw water is bypassing the filter filling the lines.
  4. moreira85
    Nov 5, 2013
    Massachusetts
    Sorry I meant after backwash.
  5. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    You are not rinsing enough. If you can change the fast rinse time it will help. If not, you will need to Regen sooner.
  6. moreira85
    Nov 5, 2013
    Massachusetts
    Merry Xmas. I have the brine draw set to 60, rapid rinse at 10. I changed the RR to 13 last time around w little improvement. That's what it seems like it's not rinsing it enough. It doesn't seem like the unsoftened water that's coming through, I don't have a leaky toilet or R/O system. It seems like water that was being back washed.
  7. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Brine draw? So then this is a softener, not an iron filter? If so, the regen was the right term. I was confused by the 7 day cycle.
    Either way, a softener during regen or a filter during backwash, goes into a bypass mode so the raw water can get by it into the plumbing. If this is on a well system with the pressure rising and falling, and if there is an expansion tank downstream then that too can contribute. A longer fast rinse might not make any difference.
  8. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Please post again some numbers.
    Iron?
    Hardness?
    Mn?
    Number of people?
    Size of unit? as in what was the max capacity from the company you bought it from?
  9. moreira85
    Nov 5, 2013
    Massachusetts
    40000 grain cap. 2 adults 2 young children. We don't use a lot of water. Iron 1gpg. Iron 3ppm. I'll have to ceck MAnganese but it was Low.
  10. moreira85
    Nov 5, 2013
    Massachusetts
    If it helps at all the first 4 to 5 weeks there were no issues after back washing.
  11. Akpsdvan
    Dec 29, 2009
    Alaska
    Is the iron at 1 or 3 and the hardness?
  12. moreira85
    Nov 5, 2013
    Massachusetts
    Sorry iron 3ppm. Hardness 1gpg. I have the hardness setting on softener at 17.
  13. Akpsdvan
    Dec 29, 2009
    Alaska
    I was working with a comp hardness of 22 grains and a capacity setting of 25 for the system.
    With say 3 people 75per day that would be 225.. or about 4-5 days.
    I am thinking that the unit has been set up to go to long between regens and the media is building up with iron..
  14. moreira85
    Nov 5, 2013
    Massachusetts
    That's what I had the capacity at 25. So I should adjust the hardness? How often between regents do u suggest?
  15. Akpsdvan
    Dec 29, 2009
    Alaska
    As before I am thinking about a default setting of 5 days and make sure that the reserve is on Fixed Reserve Capacity of say 225gallons or just the 225.
  16. moreira85
    Nov 5, 2013
    Massachusetts
    Yes it's a softener with a well. It regenerates at night with no water being used while we sleep. There is an expansion tank for hydronic baseboard. It looks like water from the backwash not hard water that got into the plumbing.
  17. moreira85
    Nov 5, 2013
    Massachusetts
  18. Akpsdvan
    Dec 29, 2009
    Alaska
    So you will increase the brine refill time but not change the default day to 5 from the 7?
    I am working on getting the mind around why you are set on so long of a time frame between regen cycles.
  19. moreira85
    Nov 5, 2013
    Massachusetts
    I'm not set on it. I've regenerated twice in a day then the next and each time the same result. Yellowish water right after the regen.
  20. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Do you have an external trio of bypass valves? If so, humor me and close off the house side while you manually regen and then open it up afterwards to see if you still get yellowish water.
    I contend that either there is enough water use or expansion during the cycle to let the dirty backwash water get forward of the softener.
  21. moreira85
    Nov 5, 2013
    Massachusetts
    I have a shut off after the softener between my softener and sediment filter.
Similar Threads: Regen coloring
Water Softener Forum, Questions and Answers Katalox Light regeneration using Chlorine solution Feb 17, 2017
Water Softener Forum, Questions and Answers How long before forced regeneration? Feb 5, 2017
Water Softener Forum, Questions and Answers How to set regeneration time on a 5600 Econominder Jan 23, 2017
Water Softener Forum, Questions and Answers Water pressure low and water not clear after water softener regenerates Dec 11, 2016
Water Softener Forum, Questions and Answers Won't auto-regenerate, manual OK Dec 2, 2016
