Refrigerator is Hot - 120 Volts at Handle
Discussion in 'Electrical Forum discussion & Blog' started by molo, Jan 23, 2012.
  1. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    If the ground was connected properly then you should not get shocked even if the AC polarity was reversed.
    Did you get it wired correctly ?
  2. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    It may have been just capacitance building up voltage on the fridge's frame without any real conductance, or, on the other hand, a leakage current from the circuits in the fridge and enough to give a good tingle or more; still, can't be too safe without a gound to drain it away or trip a breaker if it was a real short to the frame from the hot.
  3. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I would have expected it to pop the breaker, just as soon as plugged in. Or it has no Proper Ground.
    I think there is more to this picture.
    I have some Popcorn.
  4. molo
    molo Member
    Sep 23, 2006
    Cold New York
    The electrician rewired the outlet. There is no ground wire and the wire is two insulated wires wrapped in a rubber/plastic type coating.
  5. BobL43
    Mar 25, 2011
    Long Island, NY
    Kleenex ® :p
  6. ballvalve
    Dec 28, 2009
    northfork, california
    Originally Posted by ballvalve
    Whats terrifying is that they came WITH a battery and actually work.
  7. BobL43
    Mar 25, 2011
    Long Island, NY
    Man you got that right!
  8. Homeownerinburb
    Homeownerinburb New Member
    Jan 14, 2012
    Los Angeles, CA USA
    Ah. Old non-metalic cable without a ground. I found a bit of that in a house in Pasadena. I think the wire dated to the '40s or early 50's, to judge from the other elements that I saw.
    There was a good bit of knob and tube in the house as well. Apparently there is quite a bit of that left in Pasadena and the towns around it. A real pain when combined with lath and plaster.
  9. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Sounds like you were correct Bob.
    If there is no ground connection in the box then you would be measuring the device leakage.
  10. BobL43
    Mar 25, 2011
    Long Island, NY
    Oh, how shocking! Thanks Don:cool:
  11. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Request for more interpretation
    I may be misreading the posts, but although the outlet has been rewired, can the fridge still shock someone?
    Thanks,
    Bill
  12. BobL43
    Mar 25, 2011
    Long Island, NY
    It definitely is possible. Take a voltmeter and take an AC volt reading from the frame of the fridge to a ground connection (water pipe, or ground from another outlet that has a ground). If you can measure (hard for me to say how much voltage will give you a feelable shock) 24 volts or more, than you might feel a tingle if its just capacitance as I said above. If there is a real short circuit from the hot circuits in the fridge to its frame, then it will be dangerous. I guess your electrician must have checked this out for you in the name of safety?
  13. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    @molo: Unless there was some connection between the fridge frame and one of the electrical conductors, it would not be possible for
    anyone to get a shock from it. That is the root cause of the problem. If the receptacle was miswired (reverse polarity), it is all well and good
    to correct that problem, but the fault in the fridge remains. If, for instance, there is a short between what is now the grounded conducter (neutral)
    and the fridge frame, then at present there is no shock hazard; however, by simply reversing the power cord plug in the receptacle the fridge frame
    would again become energized. More indirectly, any modifications to the circuit feeding that receptacle that alters the polarity (very common in ungrounded
    house wiring systems, unfortunately) would also recreate the shock hazard. I am rather astonished that the electrician did not address the fridge wiring
    problem, where the real problem lay. A receptacle with reversed polarity in an ungrounded wiring system is really a minor defect, and extremely common.
  14. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Shouldn't the shell/handle be insulated from the current conducting components of the fridge (motor, wiring)? It seems a very dangerous design otherwise. The hinge on the freezer handle caused the original shock. Can this happen without a short in the fridge?
  15. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    Can this happen? Yes
    Can this happen without something being wrong with either the fridge or the circuit it is plugged into? No.
  16. Bobelectric
    Bobelectric Electrical Contractor
    Feb 16, 2009
    Eighty Four,Pa. 15330
    I can't understand the replys to this tread. Sounds like repair guy f*** up. Refers don't bond to frame. A circuit with an adapter to plug into a non grounding receptacle.Hot frame.
Similar Threads: Refrigerator Volts
Electrical Forum discussion & Blog Refrigerator problem: freezer keeps defrosting Apr 1, 2008
Electrical Forum discussion & Blog Volts leaking to ground rod Feb 19, 2014
Electrical Forum discussion & Blog Portion of 240 Volt Circuit only Delivering 120 Volts to Baseboard Heaters Nov 23, 2013
Electrical Forum discussion & Blog Code question 277 and 24 volts same fixture. Sep 27, 2012
Electrical Forum discussion & Blog What's the difference between 240 volts and 220 volts? May 13, 2008
