Refrigeration grade 1/4" coil ok for refrigerator water /ice?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by whoru9999, Mar 3, 2011.
  1. whoru9999
    whoru9999 New Member
    May 7, 2010
    illinois
    Hello,
    I am running a new line to my refrigerator for ice / water. I have some 1/4" copper coil tubing that is refrigeration grade. Can I use that for the run, or should I buy utility grade?
    What is the difference between the 2 types?
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    it is fine. refer grade just means that it has been evacuated with nitrogen and the ends sealed against moisture.
  4. hj
    REfrigeration grade means it is a thinner tubing than "L" or "K", but also not the same as "M". Reefer tubing in all sizes comes in 50' foot coils rather than the 60' and 100' common to plumbing grade tubing. I have seen people use 3/4" and 1" reefer tubing for buried water lines because it was "cheaper" than the plumbing tubing. They were unaware, or unconcerned, about it being a thinner material. In the smaller sizes 1/4" and 3/8" reefer tubing is usually all you can get.
  5. mrd
    mrd New Member
    Aug 3, 2010
    de, us
  6. jimbo
    jimbo Plumber
    That is true. To be consistent, we should all refer to an icemaker hookup as 1/8" tube since it is for water. But the fact is, the industry and the trade have universally adapoted "acr" terminology when referring to water tubing in sizes less than 1/2".
  7. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    Utility grade has the same OD as ACR, but is thinner walled.
  8. hj
    quote; Utility grade has the same OD as ACR,
    ALL copper tubing has the same o.d., regardless of whether it is specified by i.d., or o.d. Fittings would NOT work with it if there were different o.d.s.
  9. Tom Sawyer
    Nov 29, 2010
    Maine
    At any rate 1/4" refrerigeration tubing will work just fine.
  10. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You might want to consider using a flexible line with steel mesh over it. These don't kink when you move the refrigerator.
  11. Tom Sawyer
    Nov 29, 2010
    Maine
    Yes Gary, good post. You can get the entire kit, braided stainless line, valve and all the connectors from fluidmaster
  12. hj
    We might have two different situations here. The braided hose is for use in connecting the water TO the refrigerator, once the water line is in the area, but he might be using the copper tubing to GET the water to the refrigerator area.
  13. whoru9999
    May 7, 2010
    illinois
    After reading all of this, I decided to just sweat some new 1/2" L and make a new run that terminates with a valve behind the fridge. I will use SS braided from the valve to the fridge.
    Seems like the most professional way to go.
  14. Gary Swart
    Sep 1, 2004
    Yakima WA
    That's what I thought you were doing in the first place. After reading HJ's reply, I could see there was another possibility in your question. FWIW, when I did my installation, I spent a couple of bucks extra and put a ball valve after the tee in the main line so if ever necessary, I can shut off the water to the entire ice maker line at that point.
Similar Threads: Refrigeration grade
Plumbing Forum, Professional & DIY Advice Pipes above or below insulation with unusual insulated slab on grade Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Professional grade tube/fitting brushes and tube cutters Feb 23, 2016
Plumbing Forum, Professional & DIY Advice Garage Duty Grade Faucet/Mixing Valve Mar 8, 2014
Plumbing Forum, Professional & DIY Advice Water supply upgrade questions Jan 12, 2014
Plumbing Forum, Professional & DIY Advice Detached Garage Bathroom slab on grade Sep 27, 2013
