reducing toilet noise
Discussion in 'Toilet Forum discussions' started by crmcdesign, Dec 21, 2004.
  1. crmcdesign
    crmcdesign New Member
    Dec 21, 2004
    I'm looking for every trick in the book (and then some) for minimizing toilet noise from upper floor, transmitted to main level living area. This is a new installation. I am worried about the noise of toilet flushing, toilet filling, and use of toilet. Has anyone heard of special gasketing that isolates toilet fromthe floor? What is the best material for waste pipe? Any other tricks? Special pipe hangers? any advice would be most appreciated. Thanks.
  2. jimbo
    jimbo Plumber
    In terms of the waste piping, cast iron is always considered to be the quietest. I believe it would be important for the drop AND the elblow and horizontal run to the stack. I believe a good installation, including insulation, may be as important as the pipes.
  4. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    Be Quiet Mr. Toilet
    I certainly agree with Jimbo's comment about cast iron piping transmitting less noise. However, your structure is already built. Replacing your current toilet with one that produces less noise may help those in your living room from hearing the toilet flush.
    I've not heard of any special gasketing to isolate the toilet from the floor. Piping that touches framing members does transmit sound. Hangars alone will not prevent the contact.
    The first harm in your case is the architectural plans that specified the design and material for your home. It is expensive to correct the design/material causes after installation and most attempt covering as a more reasonable alternative to correcting.
  5. King3244
    King3244 New Member
    Dec 14, 2004
    Kelowna, BC
    Two ways to reduce noise.............either cast iron or copper for your vertical drain, ABS is noisey, you can hear the water running down it. Also make sure that nothing in your piping is touching any framing member in the house.
    North
Similar Threads: reducing toilet
Toilet Forum discussions reducing flange Dec 24, 2008
Toilet Forum discussions Reducing noise in TOTO Aquia trap Sep 20, 2007
Toilet Forum discussions Toilet Flange not Flat/Level Tuesday at 2:21 PM
Toilet Forum discussions How is the toilet made the difference between 1.28 and 1.60 GPF toilet? Saturday at 9:18 PM
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Saturday at 9:06 PM
