Reducing from 2" to 1-1/4 inch. Where to get the fittings?
garnell22
Does anyone know where I can get a 2x2x1-1/4" tee or a 2x1-1/4" 90 degree elbow?!
I've been looking and can't find anything. I need to connect a sink (from Spain) that has a 1-1/4' drain to a 2" waste pipe.
Thanks!!
Marc.
Krow
Ontario, Canada
If you could even find these odd sizes, you will be paying a premium.
It may be easier and cheaper to get 2x2x1 1/2 T with a 1 1/2 x1 1/4 bushing
And a 2" elbow with a 2x1 1/4 bushing
garnell22
Thanks guys.
I did as suggested and got a:
2x2x1-1/2" tee
1-1/2" 90 elbow
1-1/2 x 1-1/4" trap adapter (brushing?)
My problem now is that the elbow plus the trap adapter together are about an inch too long for my 2x4 stud wall (i.e. the trap adapter would stick too far out past the dry wall).
I'm trying to install a floating sink (no vanity) so I want everything to look really good under the sink as it will all be exposed.
Any suggestions? Thanks!
TedL
NY Capital District
Huh? You're doing your reducing at the adapter, per the parts list and picture above. The el shown is 1.5 x 1.5. Just swap for a 90 degree street el.
Rmelo99
Network Engineer
How about a 2x2x1.5 tee.
Then a 1.5 x 1.25" trap adapter that is male
and a box flange in chrome to cover it all up. Use a standard 1.25" chrome trap and your all set.
garnell22
Ah, got you Ted. I actually found a 90 degree elbow with a male end. I'm hoping this will save me having to use an adaptor at all!
