Redesign of a jack & Jill bathroom
Discussion in 'Shower & Bathtub Forum & Blog' started by spfrancis, Jun 10, 2014.
  1. spfrancis
    spfrancis Member
    May 31, 2014
    Virginia
    So I'm wanting to redo my bathroom in a condo that we absolutely hate. I have attached a picture of the area, were you have two half baths with a shower area in the middle. The top pictures is the current state, and the bottom is my idea of what a good design will be. My goal is to try to make 2 full baths out of a current 1.5 bathroom setup. The doors drive me crazy, as it makes the a small area seem even smaller. If we get rid of the 2 interior doors, and make shower wall A& B just a piece of glass, versus drywall, and stub, we would save much room. I know that the drain for the shower is going to have to be a tricky part, as it is a condo. We do have access from below, as we are on the 2nd floor, and below is the parking garage. My idea is that we would have 2 linear drains that could drain down to the same pipe that would be on the shared wall between the shower areas. I was thinking of having a piece of frosted glass between the 2 shower areas, to save on space, andd make the shower area as big as possible. Any thoughts.
  2. hj
    Unless you make the two showers with a single "pan" with the glass panel as a divider, you will have a very difficult time making them "leakproof". Most condo associations would want the work done by a licensed contracor complete with permits and inspections.
  4. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Two baths out of one 1.5" waste line (old tub line).
    I hope you are friendly with the neighbours below your suite. And they don't mind you busting up their ceiling so you can have your extra shower...
  5. spfrancis
    spfrancis Member
    May 31, 2014
    Virginia
    jh,
    Yeah, I was thinking of making it a single pan, and just a divider sitting between the 2 areas. I'm almost thinking the glass wouldn't even need to sit on the ground but be 1/2 inch off of the floor. I wouldn't think that would be a big privacy thing.
    John, to your comment about flooring. Yeah it wouldn't work if we weren't on the 2nd floor, and below us is the open garage. our neighbor did something similar, where he made the one side a powder room, and the other side a larger shower area. He was able to get access to the concrete in his shower floor, to move the drain lines to a different spot.
  6. eurob
    eurob master tile and stone installer
    Feb 16, 2013
    Montreal
    I would put the linear drains near the wall A and B .
    Is the glass divider going all the way to the ceiling ?
  7. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Lucky floor plan.
    If you can add in the new drain line then go for it. Careful what drains you buy - some can rust!
  8. spfrancis
    spfrancis Member
    May 31, 2014
    Virginia
    Roberto,
    Yeah my thought was to have the glass divider go to the ceiling, and to the side walls. My thought was to keep the bottom of the glass divider off of the floor to let water flow into a common drain, and also not have to deal with the slope of the floor. My thought was to do clear glass on the small sections below A&B, to make the room look biger. My wife isn't crazy about clear glass, as you could have someone sitting on the can while someone else is showering. The size of the bathroom, I just don't see it being used that efficiently.. :)
    I really like the use of linear drains, if I can have both drains got to a common spot for draining.
    John, is there any particular drain to look at for this application?
Similar Threads: Redesign jack
Shower & Bathtub Forum & Blog Cast iron drain...can I avoid the jackhammer? Jan 13, 2017
Shower & Bathtub Forum & Blog Jackhammering Noise in Bath/Shower Jan 13, 2006
