huttarl
When replacing a flush valve, the replacement flush valve instructions say: before removing the old flush valve, mark the existing water level in the tank after the flush valve closes, before the tank refills. But in my case, the old flush valve is broken -- that's why I'm replacing it! The old flush valve doesn't open or close unless I make it do so.
So, how do I figure out the recommended after-flush water level in the tank? The toilet is the AS Champion 4 (model 4260). I'm replacing the original flush valve with a Korky 5030BP.
(See earlier post https://terrylove.com/forums/index....-flush-valve-american-standard-champion.65304 if you want more context.)
