Recommended brands of gas water heaters
Discussion in 'Water Heater Forum, Tanks' started by mkulter, Feb 2, 2013.
  1. mkulter
    mkulter New Member
    Feb 2, 2013
    We're having to replace our gas water heater after 14's leaking. I'm trying to find out what brands are recommended. I googled reviews and found that Whirlpool and GE have a lot of negative reviews.
    What brands do you recommend and does the number of years on the warranty mean it's a better water heater?
    Any help would be appreciated!
  2. jadnashua
    Whirlpool is made by a consortium which puts the client's name on them...must be 4-5 major brands all made in that same factory.
    GE is made by Rheem, and generally is a decent product. If you get a GE at HD and call the 800 number, they answer Rheem. Not a bad choice either rebranded GE or a Rheem itself.
    Bradford White makes a nice product, but generally, it is only sold to plumbers, it may be hard to find if you want to buy one directly.
    In most cases, on the same heater, you can pay extra and get an extended warranty. Generally, it is not a different're buying an insurance policy. Sometimes, they'll replace the plastic drain valve with a brass one, but you can do that yourself and probably come out many dollars ahead. A longer warranty tank might have a second or larger anode, but again, those are easy to check and replace at far less than the cost of 'upgrading'; and, many of them are exactly the same with no 'upgrades' to the hardware, only a different label and piece of warranty paper.
  4. mkulter
    mkulter New Member
    Feb 2, 2013
    Thank you for the info :D
Similar Threads: Recommended brands
Water Heater Forum, Tanks Recommended brands/models for instant near-boiling hot water heater? Mar 30, 2014
Water Heater Forum, Tanks Recommended Oil Furnace/Boiler Temp? Jan 31, 2012
Water Heater Forum, Tanks Which water heater brands are better? Apr 27, 2014
Water Heater Forum, Tanks Good Water heater brands? Reliance, Kenmore.... Mar 27, 2013
Water Heater Forum, Tanks Reliable brands? Apr 27, 2012
