Recommendation to replace Heatmaker Combi Boiler
Discussion in 'Boiler Forum' started by sagepatrol, Oct 8, 2009.
  1. sagepatrol
    sagepatrol New Member
    Oct 8, 2009
    Vermont
    We have a 23 year old HeatMaker Plus combination heat and hot water unit on its last legs. We have an interior (not an end unit), two-story VT townhouse (built in 1986-900 sq ft) with a simple, single loop baseboard system. Propane. The dedicated boiler room is 4' x 7' with a horizontal vent (8' high). Municipal water supply (7.8 ph, 6 GPG).
    We've spoken with four contractors (all recommended by others) and are having trouble deciding on the smart replacement.
    We have been told basically two options:
    A) Laars Endurance 110 combi. Cheapest solution. Successor to HeatMaker. Most of our neighbors have gone this route. Replacement quoted at approx. $5k (possibly $4k if we source unit ourselves). Will realize some fuel savings with the newer unit. One contractor felt that the unit was not especially reliable. Unit carries 20-yr warranty.
    B) Triangle Tube Prestige Excellence 110 combi LP. Net Replacement cost of approx. $5500. ($7k minus $1500 tax credit.) Only 10 year warranty. More efficient unit, but one contractor felt that actual difference in savings performance would not be dramatically noticeable. Said 95% efficieny ratings were not real in terms of actual performance for our system, said we'd probably run more in the 80% range.
    Two questions:
    1) Which of these options would you select?
    2) Are these the only two options? What about a single high efficiency wall hung boiler & tankless water heater? The space seems large enough to accommodate the two units, but perhaps they couldn't be vented properly.
    Eager for some insight . . . .
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I would go with a Baxi Luna first and the Triangle tube as a second choice.
  4. sagepatrol
    Oct 8, 2009
    Vermont
    Haven't heard of the baxi luna. Can you elaborate why we should consider Baxi Luna 1st, then Triangle Tube 2nd?
Similar Threads: Recommendation replace
Boiler Forum Need New Boiler Manufacturer Recommendations Feb 22, 2016
Boiler Forum Boller and Circulating Pump Recommendations Feb 1, 2015
Boiler Forum Boiler Fill/Pressure Reducing Valve and Relief Valve recommendations Nov 11, 2013
Boiler Forum Should I replace ~70-year-old boiler? Mar 5, 2017
Boiler Forum Burnham RS-109 DHW coil scaled. Searching options for replacement (all or DHW only) Jan 23, 2017
