recommendation for wall hung "closet carrier"?
Discussion in 'Toilet Forum discussions' started by Royboy, May 27, 2006.
  1. Royboy
    Royboy New Member
    May 27, 2006
    I am looking at the possibility of installing a wall hung toilet to deal with a mislocated toilet flange in a radiantly heated slab. I would need to discharge the drain horizontally (to the left) once inside the wall cavity and don't need to vent right at the carrier as there is a 3" PVC stack a couple feet to the left in the wall.
    2 questions:
    1) any recommendation of makes of carriers? critera include horizontal discharge, minimal wall depth, relatively low price :)
    2) what wall depth am I likely to need?
    thanks - Roy
  2. jimbo
    jimbo Plumber
    Carriers are not cheap. Go to a large plumbing supply house and see what they carry in stock. If they don't stock what you need, they have the catalog and can order the right thing.
  4. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Check out the price for the toilet/carrier combination. I don't know of such as thing as a "relatively low price" wall hung toilet unless you are comparing it to one of those fancy things that automatically wash and dry you after you have finished.
  5. Joerg
    Joerg New Member
    Oct 6, 2004
    Califonia
    Hello Bob,
    Zurn makes a whole lot of carriers:
    http://www.zurn.com/pages/catalog.asp?ProductGroupID=80&ProductName=Z1212#p2159
    Wall hung is definitely not cheap. We had that situation and changing to a floor mount. Usually wall mount toilets are north of $400 and carriers can set you back a few hundred as well. Our walls are all 8", maybe 6" can suffice but I wouldn't know. Anyhow, there is a whole lot of load on that carrier and the wood members in the wall. The old wall mount I took out had a piece of wood underneath by the former owners because the thing began to sag. I was very surprised that it didn't leak. It's outta here.
    Regards, Joerg.
  6. hj
    Wall hung
    Unless you set the toilet seat rather high, you are still going to have to break some concrete because the connection for a standard height toilet carrier is beneath the floor.
  7. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    geberit wall carrier cost about $375
    use a carrier system designed for residential. you will need a 6 in wall. the toilet will cost about another $200. It can all be roughed in above slab if you have a 3" drain available.
  8. Royboy
    Royboy New Member
    May 27, 2006
    thanks for all the thoughts, guys
    I will be talking with my wholesalers tomorrow morning and see what they have or can get.
    the homeowner is not happy with the current location of the toilet flange and so it appears that it's either a wall-hung or busting into a slab with radiant tubing and creating another drain exiting the building and tying together outside with the main drain line. the latter was his idea and the wall hung is mine. I think the plumbing will tie OK to the main vent stack in the wall, a couple feet down, that served the original toilet location. and, conveniently, he is a very tall guy and is mounting all the fixtures way beyond what I'd recommend (the lav is at 42" and the original toilet was planned to be an ADA model for extra height).
    so we shall see ...
    interestingly, my thought on this was spurred by just dealing with my first wall hung on another job, replacing an existing high-volume flush with a Crane Rexroth (which I have since learned from posts here is maybe not a great model, but there it is). so it don't ran but it pours.
    thanks - Roy
Similar Threads: recommendation wall
Toilet Forum discussions Recommendation for best wall mounted toilet with tank in the wall... Oct 6, 2016
Toilet Forum discussions Gasket recommendation for Glenwall toilet Dec 14, 2010
Toilet Forum discussions Toilet recommendation for narrow space Dec 26, 2016
Toilet Forum discussions 2 piece toilet recommendation Oct 4, 2016
Toilet Forum discussions Recommendation - Round bowl Jul 15, 2016
