Recommendation for toilet in a (sort of) back-to-back configuration
Discussion in 'Toilet Forum discussions' started by jadziedzic, Jul 5, 2010.
  1. jadziedzic
    jadziedzic Member
    Aug 4, 2006
    New Hampshire
    I'm looking to replace the circa 1990 toilets in the second-floor baths of my home; I think the existing units are 1.6 GPF, made by URC (?). The bathrooms are in a sort of back-to-back configuration with a horizontal "W" connection (see drawing). The W fitting runs parallel to the floor, with the discharge end taking a 90 downward to the drain, and the center opening taking a 90 upward to vent through the roof. The wet wall is non load-bearing, with the kitchen ceiling immediately below.
    I've read on this forum that back-to-back toilets using a sanitary wye can interfere with each other, particularly with the newer models with 3-inch flush valves. Is this configuration going to be susceptible to the same sorts of problems? Should I stick with replacement units with 2-inch flush valves to minimize any siphon action on the "other" unit when one toilet is flushed? I've been considering Toto, would need an elongated bowl (compact would be nice but not necessary).
    Re-working the drain connections will be problematic due to the amount of tear-out and re-work necessary. We've never seemed to have any interference issues in the 20 years we've lived in this house ...
    [​IMG]
    Thanks,
    Tony
  2. Terry
    Aug 17, 2004
    With that fitting, there is no way a toilet would skip across.
    Your choices are open.
  4. jadziedzic
    jadziedzic Member
    Aug 4, 2006
    New Hampshire
    Great, thanks so much for the quick answer, Terry!
  5. hj
    When the piping is installed properly, there is NO skip across regardless if the toilet you use. If they are installed improperly, there is no way to prevent it no matter which toilet you install.
Similar Threads: Recommendation toilet
Toilet Forum discussions Need recommendation for toilet please Mar 18, 2017
Toilet Forum discussions Toilet recommendation for narrow space Dec 26, 2016
Toilet Forum discussions Recommendation for best wall mounted toilet with tank in the wall... Oct 6, 2016
Toilet Forum discussions 2 piece toilet recommendation Oct 4, 2016
Toilet Forum discussions Compact Elongated Toilet Recommendations? Feb 6, 2016
