Recirculating pump - Noise in pipes
Discussion in 'Water Heater Forum, Tanks' started by mds, Jan 22, 2009.
  1. mds
    mds New Member
    Jan 22, 2009
    I have a recirculating pump in my two story house. My master bathroom is at the other end of the house from the hot water heater. There is a noise emanating from the attic above the master bathroom
    that is a mechanical noise (e.g. consistent pace) that happens daily, but especially in the middle of the night and sometimes after using hot water. Recently we had a power outage and as soon as the power turned back on, the clicking noise returned. It seems to have something to do with the recirculating pump (or the piping system over the Master), but I don't know what would make this noise. It is 3 years old and has been an ongoing problem (probably even increasing in frequency). Does anyone have any thoughts on how to diagnose and/or fix the problem?
    Thanks,
    MDS
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Check valve?
  4. pmoe
    pmoe New Member
    Dec 6, 2008
    laid off web designer
    Norwood OH
    FWIW, I just installed a Laing Autocirc1 and also noticed a noise emanating from my walls afterwards. I'm curious to know what is going on.
  5. mds
    mds New Member
    Jan 22, 2009
    What does an air scoop do and where would it be? Would it be at the water heater or elsewhere in the piping for the recirculating pump?
    Thanks,
    MDS
  6. mds
    mds New Member
    Jan 22, 2009
    When you say "check valve" - what valve? At which location? Sorry, but I don't know much about this.
    Thanks,
    MDS
  7. jadnashua
    You should not need an air scoop in a potable water system.
    Somewhere in the loop, you need a check valve. It could be built into the pump, or other controls, and may not be a separate installation.
  8. mds
    mds New Member
    Jan 22, 2009
    What does the check valve do? How would that impact on the noise that I described?
    Thanks,
    MDS
  9. C NUMB
    C NUMB Plumbing Contractor
    Jan 13, 2009
    plumber
    NPR, FL
    My question to you all, Is the water piping Copper, Pex, or CPVC. Pex and CPVC will expand and contract on the hot lines and if strapped tight against studs it will make a noise like water dripping or the clicking noise you hear.
  10. pmoe
    pmoe New Member
    Dec 6, 2008
    Norwood OH
    AFAIK, all my supply lines are copper.
Similar Threads: Recirculating pump
Water Heater Forum, Tanks hot water recirculating pump Jul 3, 2015
Water Heater Forum, Tanks Recirculating pump - remote switch recommendation Aug 18, 2013
Water Heater Forum, Tanks Water Heater Recirculating Pump Jun 16, 2013
Water Heater Forum, Tanks Recirculating loop versus Recirc pump for new construction Jan 29, 2013
Water Heater Forum, Tanks Recirculating pump not working after water heater replacement Jan 13, 2013
