recirc pump installed & now no pressure on the refrigerator water dispenser
Discussion in 'Water Heater Forum, Tanks' started by Meltbg, Dec 1, 2012.
  1. Meltbg
    Meltbg New Member
    Nov 30, 2012
    California
    We had a new water heater installed at the same time. We had a lot of air in the lines and some rust colored water came out of the bath tub after the install. Do I need a new water filter in the fridge or maybe the line needs cleaning?
  2. Terry
    Aug 17, 2004
    Lot's of rust?
    Anytime an old house is turned off and on with galvanized piping you run that risk.
    Most filters are rated for about six months, so I'm guess that was due anyway.
    If the home is copper, and you had rust from the tub spout, it may be that the spout was installed with galvanized pipe nipples, which will last as long as the tub, but will spot a bit of rust in the morning.
  4. hj
    Not enough information to give a good answer. Is the filter in the line to the refrigerator, or is it integral with the refrigerator? IF it is integral, remove it and replace it with the "plug" that came with the refrigerator and see if the flow increases. If it does, replace the filter.
Similar Threads: recirc pump
Water Heater Forum, Tanks Query: Quick hot water at shower with no recirculation pump Nov 22, 2014
Water Heater Forum, Tanks Cast Iron Pump for Hot Water Recirculation? Jul 6, 2014
Water Heater Forum, Tanks wanted; Used--recirc pump. for a 50' distance water-- May 2, 2014
Water Heater Forum, Tanks Recirculating pump - remote switch recommendation Aug 18, 2013
Water Heater Forum, Tanks Water Heater Recirculating Pump Jun 16, 2013
