Recessed light over shower
Discussion in 'Electrical Forum discussion & Blog' started by Magicrat, Dec 22, 2008.
  1. Magicrat
    Magicrat New Member
    Dec 22, 2008
    Hello,
    I plan on installing a HALO recessed light and shower trim cover over a corner (neo-angle) shower. A few quick questions....
    Does the light need to be part of a GCFI protected circuit?
    Is it ok to branch from the load side of a GFCI wall outlet to the light?
    Thanks
  2. beekerc
    beekerc IT Consultant / Network Engineer
    Oct 9, 2008
    Seattle
    recessed shower light
    standard caveat: i am not an electrician, however, i have wired two bathrooms with such lights and they have passed inspection. that being said....
    my understanding is no, unless the switch controlling the light is reachable from the tub/shower. i don't know what the code definition of reachable is, but an electrician did explain it as greater than the distance that you can reach while being able to touch a wet surface in the shower/tub. this roughly equates to 3 to 5 feet. i'm inclined to think that even if it's outside that range, since it's a switch you're likely to hit while still wet (getting out of the shower), it's probably a good idea to GFCI it anyway.
    yes. however, i would go GFCI (load side) --> switch --> light.
  4. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    GFCI protected? Short answer, No, as long as the fixture and trim is listed for the application and properly secured.
    You can only use the GFCI required receptacle power for this ONLY if the circuit feeds the bathroom in question and no other bathrooms. If it feeds off to another bathroom receptacle as many do then the answer is NO, you cannot use that power at all.
  5. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    The location of the switch plays no role at all.
    GFCI protected or not the switch can be right beside the tub/shower it just can't be within the foot print of the tub/shower
  6. GabeS
    GabeS Remodel Contractor
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    If I was all wet and touching anything that had to do with electricity, I wouldn't definitely feel more comfortable with GFI protection regardless if the code requires it or not. Don't forget code is minimum standards.
  7. jar546
    Feb 20, 2008
    USA
    Exactly, the code is minimum whether electrical or plumbing.
  8. jar546
    Feb 20, 2008
    USA
    Here is an electrical problem inside a shower.
    [​IMG]
    Photo by Mike McClogan, Home Inspector
  9. GabeS
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    Did you say that panel was inside a shower? I'm a little confused. Isn't that the main panel?
  10. jar546
    Feb 20, 2008
    USA
    Yes but it was in the way of where they wanted the shower so he cleverly made a hinged panel to cover it.
    It is not code compliant, nor is it safe but when you are trying to save money, who cares?
  11. GabeS
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    That's pretty scary. I've seen dumb things, but that might pretty much top them all.
  12. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    And if you can answer WHY to any of your statments I will be impressed.
  13. GabeS
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    Chris, I'm not sure I understand exactly what you are asking. Can you please clarify your question.
    If you're asking why I would want GFI protection, it's because the outlet would shut off if electricity starting flowing through my body.
  14. Magicrat
    Magicrat New Member
    Dec 22, 2008
    Thanks for the replies,
    Got it, no GFCI required and I will branch off the existing light circuit in the room.
    I also want to install a ventilation fan that will run off the same switch as the recessed light above the shower. The difference is the fan will not be directly above the shower (about 4 feet away). I understand that most fans require GFCI protection if "over a shower or bathtub". Does a fan require GFCI if it is 4 feet away?
    Thanks again
  15. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Exactly.
    And no, 4' away would not be considered over the shower. :D
  16. Speedy Petey
    Jun 16, 2007
    NY State, USA
    +1 ..........
  17. GabeS
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    Can you elaborate please. I'm still not quite understanding what you are getting at. Just come out and say it, don't be afraid.
  18. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    I would like to know why you would feel safer.
    If I came in out of the rain and was wet should the switch I turn on the light with be GFCI protected?
    Would it be safer if the whole house had GFCI protection?
  19. GabeS
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    Actually, yes it would be safer if the whole house had GFCI protection.
    Should every light be GCFI protected? Depends on how safe you want to make the house.
  20. GabeS
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    It's surprising that you would know the complicated answer to your light bulb question(50 watt and 100 watt and someone removes the neutral, blah blah blah) and not know the answer to the simple question you just asked.
    Are you one of those guys who are really book smart but lack common sense?
  21. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Gabe, I think it is obvious that that is not the case.
    Many folks who just don't know any better think that every electrical device in a home is inherently unsafe. You might just be one of those folks.
Similar Threads: Recessed light
Electrical Forum discussion & Blog Light Switch wired to receptacle. Can I use to add recessed lights? Sunday at 6:17 AM
Electrical Forum discussion & Blog Recessed light in fire rated ceiling? Nov 16, 2016
Electrical Forum discussion & Blog Future Size of Recessed Lighting Cans? Apr 21, 2016
Electrical Forum discussion & Blog 3 recessed lights, switch at end? May 9, 2015
Electrical Forum discussion & Blog Question about recessed light Mar 1, 2015
