Recessed light can located next to rain shower plumbing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ken.yong, Aug 22, 2011.
  1. ken.yong
    ken.yong New Member
    Aug 22, 2011
    NJ
    I am planning to install an IC recessed light can (wet location rated) next to plumbing of a rain shower in a drop ceiling. Is there any minimum distance required between the light can and the rain shower plumbing? Does the light need to be GFCI? Thanks for any help!
  2. hj
    The light should be "sealed" if it is going into a shower, and if you CANNOT reach/touch it while in the shower it would not have to be a GFCI.
  4. MarkTLS
    MarkTLS New Member
    Jul 26, 2011
    Lighting Designer and Purchasing Manager
    New Mexico
    Recessed Lighting, Showers
    Please make sure you use an approved "WET" location shower trim. Also we like the 4" Line voltage housing (wet location approved) with a CFL screwed in. Less heat and good bright soft light. Easy simple and inexpensive installation.
  5. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    Bzzzzzzzzzt!
    If it were me, and there was the slightest possibility of being touched, I would protect it by feeding it from a GFCI circuit. Even if it is rated to be inside the shower, but not in it. I don't care if it needs to be or not by code, it needs to be by me.
Similar Threads: Recessed light
Plumbing Forum, Professional & DIY Advice Code clearance between ABS and recessed lighting? Jan 12, 2013
Plumbing Forum, Professional & DIY Advice Recessed cast iron heaters Oct 12, 2016
Plumbing Forum, Professional & DIY Advice recessed tile shelf in shower Jul 1, 2013
Plumbing Forum, Professional & DIY Advice Semi-recessed vessel sink - with overflow? Milforde Semi-Recessed Porcelain Sink Nov 25, 2012
Plumbing Forum, Professional & DIY Advice Anyone used FluidMaster WaxFree toilet gasket on a flang with a recessed drain pipe? Sep 27, 2010
