Recessed 1.5" Nipple Removal?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by thebigsee, Jan 24, 2010.
  1. thebigsee
    thebigsee DIY Member
    Sep 24, 2009
    Southern California
    I'm replacing my bathtub and the drain line has a 50-year-old 1.5" galvanized nipple coming out of cast-iron that I need to remove. Problem is, the nipple is in a16" diameter pit and completely below the level of the foundation (I'm on a slab) and I can't get a good grab it with a pipe wrench.
    Any suggestions on how to get ahold of that pipe so I can twist it out?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    If all that galvanized pipe is underground, when you grab and twist it it may cause untold problems in places you can't see right now...I would be very careful...post a pic so we can see more...
  4. thebigsee
    Sep 24, 2009
    Southern California
    The galvanized is not underground -- the cast iron is. All the underground lines are cast iron.
    The galvanized was not buried, but in a pit, with the cast-iron at the bottom. I'm not worried about the cast-iron stuff, I've already removed 2 identical nipples from sink trap areas and with good leverage and a couple doses of P'Blaster, they twisted off smoothly without incident. Problem is, I can't fit a wrench into the pit.
    I've seen a wrench called a Perfecto Right-Angle Wrench that would probably take care of it easily, but I don't want to spend $250 on a tool I'll use once in my life. Next step is I'll probably try this thing from Harbor Freight:
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=97073
    I'll put my breaker bar on a socket extension and give it a big pull and see what happens. I'll update if success occurs!
  5. bpetey
    bpetey Member
    Jan 12, 2010
    CA
    The longer the extesion, the harder it will be to get out. the extension will flex/twist a little. Can you bust out a bit of concrete to get more room for a wrench?
  6. CountryBumkin
    CountryBumkin Active Member
    Sep 4, 2009
    Orlando, FL
    They make an internal wrench for removing pipe. I just bought one for around $20. It gets inserted into the pipe and a bolt is tightened that tightens internal fingers/blades against the inside wall of the fitting. You then turn a large hex on the outside of the tool to remove (or install) the fitting. Mine is for 1/2 inch brass pipe nipple but they make them for larger pipe too.
    Try this link: http://www.**************.com/Prod/...-Nipple-Extractor-1-2-capacity/59514/Cat/1022
  7. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Cut it off and use a fernco to join up to it?
  8. dcelite
    dcelite Plumber
    Oct 5, 2009
    Los Gatos, CA
    1) use an offset pipe wrench.
    2) Or... cut about a 1/2" section out of the threads inside the cast iron and will come out easily.
  9. hj
    Are you sure it is screwed into the cast iron. Most of those connections were lead joints.
Similar Threads: Recessed Nipple
Plumbing Forum, Professional & DIY Advice Recessed cast iron heaters Oct 12, 2016
Plumbing Forum, Professional & DIY Advice recessed tile shelf in shower Jul 1, 2013
Plumbing Forum, Professional & DIY Advice Code clearance between ABS and recessed lighting? Jan 12, 2013
Plumbing Forum, Professional & DIY Advice Semi-recessed vessel sink - with overflow? Milforde Semi-Recessed Porcelain Sink Nov 25, 2012
Plumbing Forum, Professional & DIY Advice Recessed light can located next to rain shower plumbing Aug 22, 2011
