Receptacle question
Discussion in 'Electrical Forum discussion & Blog' started by Nate R, Feb 5, 2008.
  1. Nate R
    Nate R Member
    Jan 11, 2007
    I perform R&D testiing at small engine manuf.
    Milwaukee, WI
    Any reason I should use the screws instead of the push in connector on a receptacle? Why?
  2. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
  4. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Only if reliability is important.
    I have repaired a few connections where the sharp device that captures the wire created a nick in wire, which subsequently broke at that point. Since then I have always used the screw terminals if they are available.
    On the other hand, I have some Square D QO tandem breakers from 1965 with push-in terminals that have served more than 40 years without any problems. There is no screw terminal on those breakers so there was no alternative to the push-in terminals.
  5. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    They tend to come out or create loose connections. The good receptacles allow you to insert the wire in the hole and then as you tighten the screw it clamps down inside--not just spring fit. Get that kind of take the extra minute to wrap them around the screw.
    Jason
  6. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    If you ever need to take the receptacle out you'll be glad you didn't use the back-stab. Also, the spec-grade back-stab receptacles I've seen don't allow #12 wire to be stabbed. I agree with Lakee911 -- the best are the back-wired ones that allow you to push the wire in directly, but use the screw to secure it.
  7. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Yes.
    More surfuce area is contacted with this method.
  8. Nate R
    Nate R Member
    Jan 11, 2007
    Milwaukee, WI
    OK, points taken. Was replacing a broken light fixture with another one that will only be there temporarily, and the new one had both the slots and screws, so it hit me to ask here about it. I've always used the screws in the past.
  9. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    I like the "back Clamp" type better.
    You strip the wire, insert it and tighten the screw.
    Pros
    reliability
    Ease of use
    Cons
    receptacle cost
Similar Threads: Receptacle question
Electrical Forum discussion & Blog GFCI receptacle questions May 16, 2014
Electrical Forum discussion & Blog Ignorant question, business replacing receptacles and switches. Oct 28, 2013
Electrical Forum discussion & Blog really simple plug/receptacle question Dec 3, 2008
Electrical Forum discussion & Blog 15 amp arc fault receptacles on 20 amp circuits? Sep 5, 2016
Electrical Forum discussion & Blog 240v receptacle conversion Apr 7, 2016
