Receptacle distance from cooking range?
Discussion in 'Electrical Forum discussion & Blog' started by skoby, Apr 22, 2014.
  1. skoby
    skoby Member
    Jun 2, 2012
    Massachusetts
    I am remodeling my kitchen. I notice that one of the existing receptacle outlets is close to the cooking range. I'm going to move it as it's too close but wondered if there was a certain distance I needed to be away from it.
    Also, while I'm asking. I am moving my refrigerator service. Is there a height requirement for the refrigerator receptacle? Thanks in advance :)
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    No to both questions.
    No restrictions or distance requirements with regard to a range.
  4. skoby
    skoby Member
    Jun 2, 2012
    Massachusetts
    That was pretty speedy, pete. Thanks :)
  5. hj
    quoe; Is there a height requirement for the refrigerator receptacle?
    NO, but some refrigerators have a specific area where the outlet has to be in order for it to slide in all the way. That area will be specified in the installation instructions.
  6. jadnashua
    For the frig, instead of a surface mounted duplex receptacle, you might want to consider a recessed single instead. But, if you put it where the manufacturer says, the thing will go all the way back. That is not necessarily true if it ever needs to be replaced, though - the new one may want it in a different location.
  7. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    I wouldn't worry about a recpt being to close to the range. Back in the day they used to come with 120V plugs installed right on them.
Similar Threads: Receptacle distance
Electrical Forum discussion & Blog Wiring Split 15 & 20 amp circuits on same receptacle Wednesday at 7:05 PM
Electrical Forum discussion & Blog 15 amp arc fault receptacles on 20 amp circuits? Sep 5, 2016
Electrical Forum discussion & Blog 240v receptacle conversion Apr 7, 2016
Electrical Forum discussion & Blog How does the Receptacle , the wiring, CB and code Relate? Mar 18, 2016
Electrical Forum discussion & Blog 20 amp or 15 amp for common household receptacle use? Dec 6, 2014
