reccomended sanitary drain grade (rise/run)
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by murena, Feb 19, 2006.
  1. murena
    murena New Member
    Feb 19, 2006
    I am installing two drains into a 3" stack that is outside my house. The first is a shower drain with 2" ABS, the second drain is the tub with 1.5" ABS. The tub drain is about 6 feet from the stack, while the shower is about 10 ft. My question, what is the reccomended grade for these types of drains? I have heard that 1/4" rise per foot run... but that seems pretty steep, and will mean I will lose more ceiling height. Please help, want to get the drains completed soon. Mike
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Minimum slope for all drains is 1/4" per foot. Even if you slipped a lessor grade past an inspector, you would be plagued with clogging problems forever. This is one of the problems a DIYer can run into after getting deep into a project. Sorry, but you can't ignore this one.
  4. murena
    murena New Member
    Feb 19, 2006
    Ok, good to know...
    Just wanted to make sure the numbers were right..
  5. hj
    drains
    Now that you have the slope correct, what are you doing to provide vents for those drains? Installing a tub and shower involves more than just running a drain pipe from them and connecting it to the first available drain line.
Similar Threads: reccomended sanitary
Plumbing Forum, Professional & DIY Advice Replacing sanitary tee Mar 17, 2017
Plumbing Forum, Professional & DIY Advice Toilet drain, sanitary tee horizontal Mar 9, 2017
Plumbing Forum, Professional & DIY Advice Broken sanitary tee in block Jan 29, 2017
Plumbing Forum, Professional & DIY Advice Laundry tub/washer sanitary tee question Jan 13, 2017
Plumbing Forum, Professional & DIY Advice Venting question: sanitary tee vs wye + 45 Jan 3, 2017
