Reccomend electric Valves into 1-1/4" PVC pipe
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Dolphin, Jan 10, 2013.
  1. Dolphin
    Dolphin New Member
    Dec 31, 2012
    NV
    I want to install some 110V electric valves in my well house project. All the pipe is 1 1/4" PVC, inside well house, 10 deg to 130 deg range of temp in the well house.
    standard pressures, <80 psi
    I would like one normally open valve, one normally closed valve... so I can apply the same control power to reverse them.....
    Any suggestions would be appreciated.
  2. greenmonster304
    greenmonster304 New Member
    Apr 16, 2011
    Hampton Bays, NY
    I think 110v valves will be expensive. You could use 24v solenoid valves with relays and a trasformer.
  4. Dolphin
    Dolphin New Member
    Dec 31, 2012
    NV
    I assumed that was the case.... any good source for all these goodies? thx
  5. greenmonster304
    Apr 16, 2011
    Hampton Bays, NY
  6. hj
    If these valves are on the same line, a "3 way valve" will do the same thing.
  7. Dolphin
    Dolphin New Member
    Dec 31, 2012
    NV
    Thanks for the links and suggestions, much appreciated....
    I think I can make a 3 way valve work... agreed, it would simplify....
    doesn't appear Irritrol makes a 3way.... any other makers for this application in 3way?
    thx
  8. hj
    Irritrol is a "lawn sprinkler" company and as such ONLY makes simple valves which are all that are needed for 99.999999+% of installations. Do an Internet search for electric 3 way valves then sort out which of the "hundreds" of replies you want to investigate.
  9. Dolphin
    Dolphin New Member
    Dec 31, 2012
    NV
    I had already done that... Asco 3way valve was the best I could find, at about $1k price range...
    two of these make more economic sense...
  10. zl700
    zl700 DIY Senior Member
    Aug 26, 2009
    Western NY
  11. Dolphin
    Dolphin New Member
    Dec 31, 2012
    NV
    Thank you for the Jandy recommendation.... these seem ideal, even their check valves...
    your NSF comment made me curious....
    for a small well house, that serves only a max. of 4 residences, do control valves require NSF? I would think not?
    thanks..
  12. expressre
    expressre New Member
    May 14, 2013
Similar Threads: Reccomend electric
Pumps and Tanks Well Forum & Blog. Water is life. need reccomendations on submersible pump for underground storage tank Jan 21, 2013
Pumps and Tanks Well Forum & Blog. Water is life. *Submersible Pump* Need Reccomendations Sep 17, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Shed for plumbing/electric Feb 17, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Well pump electric wire length Jun 23, 2016
Pumps and Tanks Well Forum & Blog. Water is life. frankin 1hp pump not starting up, but using electricity Jul 5, 2015
