rear outlet toilet install
Discussion in 'Toilet Forum discussions' started by potterboy1, Aug 25, 2010.
  1. potterboy1
    potterboy1 New Member
    Aug 25, 2010
    New York
    OK I will try to be brief with my questions. I am install a AM Yorkville in a remodeled bathroom.
    1) I am replacing the broken flange and would like to use Sioux Chief Push Tite (http://www.siouxchief.com/Drainage/ResidentialDrainage/Closet-Flanges/Push-Tite.VZ8US) is this OK for a rear outlet? SC tech help was no help. They recommened I ask AM is it OK?????
    2) I purchased a sponge rubber seal from McMaster-Carr (http://www.mcmaster.com/#toilet-seals/=8kd5wu). No glue came with it. Do I need glue? If so then what kind?
    Thanks,
    Mike
  2. Terry
    Aug 17, 2004
    I would think that both are okay.
    The floor mount rear outlet can get by without glue on the rubber seal.
  4. potterboy1
    Aug 25, 2010
    New York
    One more question:
    Should the neoprene seal fit inside the beveled part of the closet flange?
    Thanks again.
  5. jfarnold
    jfarnold Apprentice Plumber
    Mar 3, 2007
    Apprentice Plumber, primary caregiver to two child
    Metro DC
  6. potterboy1
    Aug 25, 2010
    New York
    OK problem number 450...I was just trying to install the Sioux Chief Push Tite (http://www.siouxchief.com/Drainage/R...ush-Tite.VZ8US) flange which is suppose to fit inside a 3 inch PVC pipe, but low and behold I have ABS drain pipe and the gasket on the flange doesn't come close to forming a seal to the inside of the ABS pipe. I can easily pull the flange into and out of the pipe and when installed there is enough room for it to wiggle around at the gasket end of the flange. So now I am assuming that ABS has different dimensions than PVC? Who knew? Not I of course. Any suggestions before I continue to go insane with this problem? Sorry all for the rant but I needed to vent.
    Mike
  7. jadnashua
    Drain pipe is specified by the internal dimension, so a 3" pipe is a 3" pipe ID, regardless of the material it is made of. Something's not right here, but it isn't obvious from this end.
  8. potterboy1
    Aug 25, 2010
    New York
    Here is some more info. I did a rough measurement of the ID of the drain pipe and it is about 3 1/8 inches.?. Then I measured the OD of the gasket of the replacement flange and it is about 3 1/8. That explains the loose fit but it doesn't solve my problem. My house was built in 1965 and I am located in the northeast USA. Was there ever an odd ball black plastic pipe size that was used in that era. I am grasping at straws here.
  9. hj
    quote; Drain pipe is specified by the internal dimension, so a 3" pipe is a 3" pipe ID, regardless of the material it is made of.
    good idea in theory, but NOT in practice. The pipe size is a NOMINAL dimension, but since the O.D. is fixed, (otherwise you could never mix fittings), the i.d. varies according to the wall thickness, EXCEPT for S&D thin wall PVC, which DOES maintain the proper i.d, but since the pipe wall is thinner, that makes the o.d. less than the other classes of pipe so you need adapter bushings to join it to standard fittings. BUT sch. 40 PVC and ABS have the same o.d. and i.d.
  10. potterboy1
    Aug 25, 2010
    New York
    OK here is my next thought. After looking at the Sioux Chief Push Tite (http://www.siouxchief.com/Drainage/R...ush-Tite.VZ8US) flange I noticed that the rubber seal sits slightly recessed in a groove. So now I pulled the seal out of the groove and slid it back so that it is on the wider part of the pipe thus making the seal a little wider. I tried it in the DWV pipe and now the edges of the seal touch and fold back. I am going to stop into HD and try one of the Sioux Chief Push Tite flanges "off the shelf" and see what type of engagment there is in a standard 3 inch pipe. Any thoughts?
    Thanks
  11. potterboy1
    Aug 25, 2010
    New York
    This is my final setup for the flange installation. The engagement of the Sioux Chief Push Tite with the gasket pulled back out of the groove was the same as a standard one at the hardware store. So to double up on the seal I bought another Sioux Chief Push Tite and removed the gasket and put it on with the other one ( 2 gaskets on one flange). Then I added plumbers putty to the flange so when inserted into the DWV pipe it would seal to the end of the pipe to the backside of the flange. I know overkill but I really don't want to have to go back and fix a leak after I am done installing the toilet. Now the toilet is installed (Saturday)and so far so good (Monday). No leaks (fingers crossed).
Similar Threads: rear outlet
Toilet Forum discussions Floor mount rear outlet Barrington vs Yorkville Sep 16, 2016
Toilet Forum discussions Rear outlet toilet question Aug 1, 2016
Toilet Forum discussions Caroma Sydney Rear Outlet Floor Mounting Oct 1, 2015
Toilet Forum discussions Replacing old Briggs 7340 rear outlet floor/wall mount Sep 12, 2015
Toilet Forum discussions Rear Outlet Floor Mounted Toilet- HELP Jul 28, 2015
