rear exit toilet
Discussion in 'Toilet Forum discussions' started by indyjps, Sep 30, 2006.
  1. indyjps
    indyjps mechanical engineer
    Jun 7, 2006
    mechanical engineer
    indianapolis (fishers) indiana
    looking to do a budget basement bathroom, can i use one of these toilets, i have access to one for free. http://www.needplumbingsupplies.com/Kohler/Specs/116819_4.pdf
    its a kohler highcliff rear spud toilet, i am not real familiar with these. what will this require to install, im assuming a flush valve etc like a commercial toilet, will this be compatible with a lift station in the basement install.
    a friend gave me a briggs rear exit toilet for free already but it has no tank and from the sounds of the replies to other briggs questions it sounds like thats a dead end, no tank = no part # = i dont know what i have.
    thanks
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Sloan makes the parts you need. Yes it will work with a sewage ejection pump / lift station.
    If it were me I would go with a conventional toilet, but then Blackrasberry is my favorite ice cream.
  4. Phil H2
    Phil H2 New Member
    Sep 12, 2006
    Tujunga, CA
    A new flushometer (flush valve) for the free toilet may cost more than a new conventional toilet complete. You may need to increase your water supply piping to use a flushometer.
  5. Terry
    Aug 17, 2004
    It will require at least a 1" water line to the toilet for it to work.
    Most homes aren't piped for flushometer valves.
    In commercial settings, we are running pipes in the 1.5" to 2" range, with large 1.5" water meters and branching off with 1" for each fixture.
    A tank type toilet would be the right way to go.
    The bowl shown, is not really a rear outlet bowl, it's a rear spud (inlet) bowl.
  6. indyjps
    Jun 7, 2006
    mechanical engineer
    ah now i understand, on the rear spud. im having problems with choosing the right set up for my basement install. my initial thought was to use a rear exit toilet to prevent having to cut into the floor to run plumbing in the slab. is this the correct way to go about it. i would prefer to use a rear exit and lift station but they are pretty expensive for me right now looking at $350 for rear exit toilet plus the cost of the lift station.
    another thought is to install a urinal and no toilet and use a lift station without a grinder pump (laundry/sink pump style), this would clearly mark the basement as guy territory but may not be the best for resale.
    i will also be installing a bar sink.
    thanks for any ideas, i want to do it right but ill have to wait on funding if its going to be $1000 between the toilet and lift station.
    any thoughts on using the free briggs rear exit toilet
Similar Threads: rear exit
Toilet Forum discussions Bright White Rear Exit "Comfort Height" Toilet Aug 28, 2009
Toilet Forum discussions rear exit vs. wall mount May 30, 2008
Toilet Forum discussions Replace rear drain with a ground drain toilet Dec 12, 2016
Toilet Forum discussions Any creative solutions for top of tank rear inlet water supply? Nov 16, 2016
Toilet Forum discussions Floor mount rear outlet Barrington vs Yorkville Sep 16, 2016
