Rear Discharge toilet in basement???
Discussion in 'Toilet Forum discussions' started by slowgsxr97, Jan 24, 2014.
  1. slowgsxr97
    slowgsxr97 New Member
    Jan 24, 2014
    Illinois
    Hello, Im looking to put a bathroom in my basement but really do not want to bust the concrete floor up. I drew a little sketch of what is on my 4" stack now, just bought the house, and a possible after. Is this to much stuff on a 4" stack? The kitchen is on the other side of the house and has its own 2" vent
    Can I ad a rear discharge floor mount toilet directly to the stack? It would be 18" from the stack.
    Then to the left of the toilet have a washer, sink, and shower pumped and vented to the same 4" stack, via something like this
    Here is a horrid sketch of what I have now
    Here is what I am thinking. Having these 3 pumped and vented to the 4" stack.
    Will the rear discharge work? Its $249 I would rather pay more for the toilet then break up my floor. The pump for the shower/sink/washer is about the same price.
    Any input is appreciated, Thanks.
  2. Terry
    Aug 17, 2004
    You will need to vent the toilet before it enters the stack. Otherwise, everytime a toilet is flushed upstairs, it will make the lower bowl lose water.
  4. slowgsxr97
    Jan 24, 2014
    Illinois
    would it vent back into the stack just anywhere? or does it need to be vented above where the main floor toilet ties in?
    If I put a 4x2 reducing tee in above where the main floor toilet ties into the stack would it be sufficient to vent all the basement things into the 2 inch "washer,shower,sink,toilet" ?
  5. jadnashua
    You can join into the existing vent 42" above the floor OR 6" above the flood rim of the highest thing draining into that line - whichever is higher. The new vent does not need to go all the way up and out the roof if it can join into the existing one. Now, the overall required size of the vent that goes up from there has some rules (the more things that vent, the bigger it needs to be). As I understand it, that is governed by the amount of fixture units. Each type of thing (sink, washing machine, etc.) has a FU assigned to it. It's also possible that different codes allow different values, so you'd need to know what code cycle is used where you live.
  6. slowgsxr97
    Jan 24, 2014
    Illinois
    So... if I want to use the main stack as the vent I need to tie the basement vent stuff in above the sink on the main floor bathroom, correct?
Similar Threads: Rear Discharge
Toilet Forum discussions Need to replace rear discharge floor mounted toilet Help! Mar 15, 2015
Toilet Forum discussions Toto for rear discharge installation Mar 10, 2015
Toilet Forum discussions Rear discharge toilet Dec 18, 2014
Toilet Forum discussions Wall hung toilet or floor standing rear discharge toilet? Oct 23, 2014
Toilet Forum discussions Rear discharge Toilet help Dec 31, 2012
