Really confused
Discussion in 'Shower & Bathtub Forum & Blog' started by davis0710, Jan 11, 2008.
  1. davis0710
    davis0710 New Member
    Jan 11, 2008
    Please help if anyone can. Yesterday i fixed my shower downstairs that was a moen and that worked fine. I had low water pressure in my house and the water district came out and put a new regulator on outside b/c my pressure was too low.
    My first question is, After they bumped my water pressure up, the tub and shower in the upstairs is having a really hard time making the water hot. What would be causing this? :mad:
    My second question is, When i turn all of the faucet handle in my house (whether it be a sink or a shower) all the way over to hot, my pressure drops more than half. :confused:
    Can someone please help me with this, so i can try to fix my problem.
    Thanks for your input,
    Adam
  2. davis0710
    Jan 11, 2008
    ok guess nobody else knows either
  4. jimbo
    jimbo Plumber
    Your description is a little vague. We would need specific information about what make an model of shower valves you are talking about ( pictures help). And please clear up if you are talking NO WATER from the shower or tap, or water but not hot, and when you mention pressure drop, is it the house main pressure?? Check that with a gauge on a hose bibb.
  5. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Possibilities include:
    1. You could now have more flow than the water heater can keep up with. Do you have an instant heater or a tankless coil?
    2. They could have installed a larger or smaller PRV that is affecting your flow.
    3. Working on the pipes could have loosened up some junk that is now plugging a strainer or filter.
    4. You put in a new thermostatically controlled shower valve that is restricting flow when the temperature is low.
    You could check out some of these things and get back to us.
  6. Cass
    Cass Plumber
    Nov 12, 2005
    If the guys that replaced the valve were sloppy they may have allowed dirt/mud into the water line and it could be causing problems. Try removing the airators and inspecting them.
    Is the valve in the water heater open all the way?
    Is it a ball valve? If it is a gate or globe valve, it could be causing a restriction.
    If you have dialetric nipples on the water heater and have never had good hot water pressure since you have been in the house, it is possible that someone soldered the FIP adaptor while it was on the nipple and melted the insulation so bad that it is causing the restriction.
Similar Threads: Really confused
Shower & Bathtub Forum & Blog Hot water would not turn off, really could use advice! May 10, 2014
Shower & Bathtub Forum & Blog This really happen. Oct 5, 2013
Shower & Bathtub Forum & Blog I just need a really good shower/hand held. Aug 31, 2011
Shower & Bathtub Forum & Blog Sterling Accord Vikrell Tub - High Gloss? Is Sterling white really a light biscuit? Jan 3, 2011
Shower & Bathtub Forum & Blog Noisy Shower control knob - really noisy. Dec 12, 2007
