Reactor in a portable Miller Big 40 welder?
Discussion in 'Electrical Forum discussion & Blog' started by inillinois2, Oct 27, 2009.
  1. inillinois2
    inillinois2 New Member
    Oct 27, 2009
    illinois
    I am looking for some info on a "reactor" that is in a potrtable welder. This reactor is basically a transformer, I believe, and the welding current is controlled by the windings. I would just like to confirm that this is my problem. The welder runs fine except for the fact that the weld power cannot be adjusted to lower settings, is always putting out too much power no matter where the switch is set. Does someone know how to positively check this "reactor" as a new one is quite expensive. I am a maintenance electrician but just have never dealt with this particular unit. Thanks in advance for any assistance......
  2. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    It could be a "saturable reactor". You post schematic, we troubleshoot.
    http://www.freepatentsonline.com/3833849.html
  4. inillinois2
    Oct 27, 2009
    illinois
  5. jimbo
    jimbo Plumber
    San Diego, CA
    http://www.tpub.com/content/neets/14180/css/14180_135.htm
    There is a lot in the circuit besides the reactor ( transformer ) itself. If the reactor was bad, it likely would actually show burned. If it is an open winding, that could be determined with an ohmeter, using the schematic.
    Beyond the basic open/shorted resistance measurements, this type of device could only actually be tested in a laboratory environment. However, you should be able to arrive at a decision short of that. Basic VISUAL troubleshooting always is first, and will solve half the cases. Then basic voltage tests on the other components involved. Remember that high voltages are involved, and beyond the visual and ohm readings, this job might best be left to factory service. Of course they will replace major components and send you a large bill!
  6. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
  7. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Do you mean the 5 position range switch (I assume this is Z1 on the diagram on pg. 24) or the voltage/current adjustment?
    Is CT1 on the diagram the reactor you referred to? To me it seems to be a current transformer that outputs a signal to PC1.
    I can't find the 300w 34 ohm fine adjustment rheostat (R1) on this diagram. Scratch that, it is in the upper left corner and varies the gen. field current.
    Basically it looks like a 3Φ weld generator in series with a tapped current limiting inductor Z1 feeding a 3 phase diode bridge. A current transformer CT1 feeds back signals to PC1 and RC1 (which goes who knows where?)
    For troubleshooting you might need to simulate a very steady arc, unless you can weld and troubleshoot at the same time. 40v @ 80A is 3200W at 0.5 ohm. You can get a half ohm using a few yards of skinny copper or iron wire but to prevent melting it would have to be submerged in 3 gals. of water or oil.
    That's a problem yet to be solved.
    What options did you get, if any?
  8. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Figure 2-4 in your link tells me that the impedance of each of the three sections of Z1 should be 3 ohms at the low welding current setting.
    Power off the welder.
    Set Z1 to lowest current setting.
    Disconnect Z1 and hook a section to a 24 vac transformer (assuming the welder runs at 60 Hz from the generator).
    Measure the voltage across and the current through that section.
    V/I should equal ~3.
    With a 40 VA 'former the output V will probably drop to ~17 vac. Don't leave it on too long.
    Repeat for the other two sections.
  9. inillinois2
    Oct 27, 2009
    illinois
    I really have not yet gotten a chance to work on this but did turn welder on myself today. I am confident the reactor is not the problem as i did a visual and i sure did not smell coils burnt. What is going on is that if i have the welder turned all the way down i can still strike an arc. I talked to another of the guys at work and he told me he was using it last week and the welding rod "burnt up".
    Tells me it turned a cherry red. I am assuming the welder shorted out. I have a load tester and the generator responds as it should as i ramp up the power, just too much current. I also did a check and the generator is putting out 48 volts phase to phase vice the 42 the print says it should. I do have a Fluke Scopemeter and am as of now going to assume that the welder has blown diodes. Am I on the right track?
  10. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    It could be shorted SR3 diodes. If so, you should see some AC on the welder output with the scope, instead of 3 phase full-wave-rectified DC.
    http://wpcontent.answers.com/wikipe...ation_2.png/200px-3_phase_rectification_2.png
    Note that VR1/R4 may clip the tops of the waveform if there is no load on the welder.
    To check a 275A 300 PIV diode, hook it in series with the 48 vac from your welder and an assembly of a few 100w incandescent lamps in parallel. With the scope you should see half-wave-rectified DC with a peak value of about 67v. You could also use 120vac from your house but with a 300 PIV diode you might be pushing your luck.
    The incand. lamps provide current limiting.
    A similar diode has a forward voltage drop of 1.3v maximum at rated current and about 1 mA reverse current at 200vdc.
    If it is a bad diode, I assume it failed for internal causes and not 'cause it was overstressed, but who knows? These power levels are enormous.
    You'll need heat sink compound if you mount a new diode.
    Can you post a link to your load tester?
  11. inillinois2
    Oct 27, 2009
    illinois
  12. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Good.
    With this and a scope we should be able to isolate the problem down to a single component.
    (48v/42v)^2 = 1.3 equals 30% more power into the weld, if the arc acts like a resistor, but I don't see how a bad gen can ever put out more power than normal. Maybe R2 or R3 are shorted.
  13. Rich B
    Rich B DIY Senior Member
    Sep 13, 2008
    New Jersey
    I am a Miller Certified Service Technician. A Big 40 is usually a Continental 4 cylinder engine driven welder. All Miller welders produce AC weld output and use a rectifier for DC weld output. The rectifier on one of those is maybe an arrangement of stud diodes mounted on the endplate or more likely a set of diodes mounted in a grid of flat plates as a complete unit. A reactor is a term Miller uses for an AC circuit transformer....if it were used on the DC circuit side they would call it a stabilizer. Bad diodes usually would be low output or no output or sparks flying from a shorted diode. If your output is too hot and will not adjust properly you need to check your fine adjust R-1 rheostat . It is on the control panel and is marked from min to max with numbers. You can use an ohmeter to check it on the backside. If it has 3 wires......check from the center to one side and it should go in one direction ohmwise and from the center to the other wire it will go in the other direction. The values for it are printed right on the side of it. I worked on those all the time in the past but don't recall it being common for one to go to max output. Usually they lose output when that item goes bad. That machine is old school techonolgy...no circuit boards. Normal OCV(open circuit volts) for that machine across the weld output studs is usually about 70-80 volts if I recall right. Another possibility is that someone moved some wires because something came off due to deterioration. All Millers have a circuit drawing on the insde of the machines cover. I have access to all of that at work on my computer via Miller's Extranet........A scope is not going to help you here trust me......I have been repairing electrcial equipment like this for over 15 years........Component test everything first......Little square items with 4 wires are bridge rectifiers and you should have at least one on there. Adjutsable slide resistors are on there as well....2 as I recall. Components must be checked out of the circuit.......means you have to remove some wires to test it and you need to know what your testing and what the values are supposed to be.....I don't usually look at this area of this forum often, but maybe I can help you find the trouble......
  14. Rich B
    Sep 13, 2008
    New Jersey
    I did not realize you posted a link to the SM......I looked it over. That machine has stud diodes mounted in the end but as I said I doubt that is your probelm. Look at R-1...that is your fine adjust rheostat. Zero to 34 ohms. SR-1 and SR-2 are full wave bridge recitfiers. They are little black square units with 4 wire terminals. One corner is cut with a small diagonal. That is the DC + side. DC - is opposite and the AC's are diagonal from the DC's. They need to be Diode tested......with wires marked and removed. The other adjustable slide ring resistors are probably not your problem but they can be tested as well. Use your parts breakdown to ID each unit and read it's value if it is shown. The print shows all the wire numbers and where they go. All Millers have mostly black wires and they are numbered with white lettering. You can verify what your looking at by using that circuit diagram and checking the wire numbers. I use a Fluke DVM and print out the circuit diagram on 2 pages and tape them together......so my old eys can read them easier.....Check your wiring and the R-1 and the SR's (silicone rectifiers)
  15. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Correction:
    FWIW, each functioning diode takes about 200w from the power delivered to the arc.
    By default, from most likely to fail to least likely to fail,
    semiconductors
    VR1
    coils
    resistors
    FWIW, I think SR1 & 2 failing by shorting or opening can only reduce the weld output power, by reducing the DC field current to the weld gen.
  16. Rich B
    Sep 13, 2008
    New Jersey
    This is a DC only output machine. AC is produced by the alternator and that is the design Miller has used for many years. A similar LINCOLN machine is a generator design and produces straight DC with a segmented commutator on it's armature. A Miller uses a rotor with slip rings and brushes and produces AC. Output is rectified in the main rectifier by the stud diodes (6). Z-1 is the reactor on this machine and since it is before the main rectifier it is AC. Miller sometime confuses things by calling it Z-1 which is usually a DC circuit tranformer used to dampen AC pulses. On this machine Z-1 is the AC reactor and that is their term for an AC transformer. It is a multitap tranformer and responsible for supplying the 5 ranges of weld output. S-3 is the range switch and that is how output is selected from high to low. R-1 is the fine adjust control(34ohm rheostat). It is a wire wound ceramic unit and often goes bad on these older machine. Usually output is lost if it opens or is dirty. Both the range selector switch and the R-1 are mounted on the front panel. Shorted diodes will usually blow open and then power is reduced. If a diode is shorted the machine will act as if it is under a load. The output will be dead shorted the same as welding and the rod sticks. Bad diodes can only reduce ouput not increase it. VR-1 is a very small resistor that dampens the OCV so an arc can be struck a little softer than if it were not across the output circuit. If it is bad OCV will be higher than normal. 95 volts is the Max OCV on these machines.
    Here is one important thing that has not been mentioned.....engine speed needs to be checked. If the engine speed is to high output will be high. Engine speed can be tested by way of the AC output using a Fluke meter with frequency or Hz reading capability or an engine meter. Should be 1860 rpm Max no load. Most Millers have a 100hz 120 VAC outlet available while welding. If it has that, that is where you can check engine speed with a HZ meter.100 HZ is the proper number at weld speed for those models. It may have 60hz 120VAC available at that outlet. Either way that is where you can check engine speed. If it is not close to one of those numbers it needs to be...at weld speed....Those old carburetors and engine governors are often a mess.....
    The PC board is for the idler control, nothing else. It controls a solenoid that pulls the carb to idle with no load if the switch on the front panel is set for idle.
    The more I think about it...the more I think it's an engine speed issue......nothing else on those machines usually makes for to much weld output.......usually to little or none....
  17. inillinois2
    Oct 27, 2009
    illinois
    Got it ito work
    I had an hour today and i did get it to work. I pulled the diodes out and checked, they appeared to read good, all were very close in reading. I scoped the output dc and had minimal ac on the line. The fine current adjust was checked with a fluke and also appears to be good, a couple bad spots in it where we always have it set at, but not causing the problem. I then had someone weld with it and it welded, with both the range switch and fine current set to minimum. This was with a large electrode, so i could not get a nice thin weld as it used to do. I then took off each lead # 17, 27 and 37 one at a time and tried the welder out at the above mentioned settings. # 37 did the trick and the unit operates as it should. This is without one of the three coils of the reactor. Can i now assume that even tho the coils all read the same, the one associated with #37 has some varnish worn off and allowing part of the windings to short together? I did not have time to read individual coil windings and am not even sure it is possible. Will it badly damage the welder to operate it this way? We are lucky in the fact that we have 4 other welders that are newer and nicer than this one, i just did not want to trash this one......again, thanks to all of you!!!
  18. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    It has somehow lost inductance. If you pass 60 Hz through each coil of Z1 with a transformer you should see a difference in #37. If you don't, I am stumped. The problem is that the coil permeability probably changes with current so you might have to pass 100A of AC through the coil to read its design impedance value.
    And with Z1 set at low current and a constant load on the welder the scope should show one of the three phases higher than the others and not adjustable.
    If R equals the DC coil's resistance and X equals the coil's impedance and XL equals the coil's inductive reactance, then X² = R² + (XL)². If the coil is primarily inductive reactance, an ohmmeter won't tell you much.
    If you have the schematics for the other welders and they are still working, I'd start measuring whatever components in each one that doesn't show a schematic value for resistance or inductance. For this one I see 10 unmarked coils.
    BTW, the resistance of VR1 will vary with the voltage applied to it.
    BTW, MIG welders are described as Constant Voltage sources, so arc welders might be more like Constant Current sources, with the SR3 diode bridge acting like a current summing network and VR1 acting to limit open circuit voltage, which is theoretically infinite for a CC source. That's probably why the SR3 diodes have such a high PIV.
  19. Rich B
    Sep 13, 2008
    New Jersey
    Wires #11,21,31 are the AC inputs to the Z-1. You can put a voltmeter on those and read that voltages phase to phase. It should be close on all 3. You can also put a meter on 17,27,37 phase to phase and see if those readings are close. Weather does effect those coils and whoever diagnosed the machine as having a bad reactor seems to have made the right diagnosis OR you have a wire shorted across another wire in the S-3 range switch.......Most Miller SM's have a voltage and resistance chart for testing. It would give you test points and the proper voltages you should see in all ranges. I will take a look tomorrow at work on my Miller website connection to see if I have anything more helpfull. That is an older machine and many of the old machines have limited info available and parts like that reactor are often unavailable new from Miller.....If it was available it would be quite a job to change and very expensive. I have changed similar transformers on at least one or two similar machines in the past....
  20. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    With a constant 200A or 300A load on the welder a clamp-on ammeter should show higher AC current in wire 37.
    If you do need a new coil maybe a motor rewind shop can help.
  21. Rich B
    Sep 13, 2008
    New Jersey
    It is extremely unlikely anyone can make a reactor for this machine and or repair the one you have.
    There is a full SM available and it is T-450 for those machines. You can buy one from Miller for $15.00
    Millers have a serial number on the front panel. 2 letters and 6 numbers. It is stamped into the front panel. That number is needed to be sure to get the right part.
    There are 3 different S-3 switches listed and 2 different Z-1 reactors. One is not available from Miller. S-3's range in price from about $450 to $675. The Z-1 available from Miller is $1650.
    I make my living repairing electrical equipment like this. Miller and Lincoln welders and generators from Onan, Briggs and all the big standby manufacturers.
    You cannot repair equipment like this with without buying the proper parts from the OEM. Your wasting your time theorizing about this and that. Get a SM.....test the parts and replace what is necessary to do the proper repair or replace the equipment. Or take it to an Authorized Miller service repair facility......
Similar Threads: Reactor portable
Electrical Forum discussion & Blog Need a solution for portable generator and panel. Nov 21, 2015
Electrical Forum discussion & Blog Generac Portable Generator Nov 2, 2011
Electrical Forum discussion & Blog Is this portable generator hook-up OK? Oct 20, 2011
Electrical Forum discussion & Blog using coleman ground fault extention cord with portable generator Feb 24, 2011
Electrical Forum discussion & Blog Connecting a portable generator to home main panel May 19, 2010
