RE- Sick Septic system
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gundogblue, Oct 25, 2008.
  1. gundogblue
    gundogblue New Member
    Feb 15, 2008
    Well the septic guy was just out, he said I need the top of my septic tank re-built, and a new lid, and a new line-out from the septic tank. Also Im gonna expose all the distrobution boxes , they too my need some work, the estamate is $2500.00 it could be a little more or less depending on the shape of the distrobution boxes. And I just placed a call to a company that will pump out the tank.
    Paul
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    And your question is?
  4. gundogblue
    Feb 15, 2008
    Not really a question but some have indicated that they would like to be kept up to speed on my problem.
    Paul :)
  5. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Oh... In that case, best of luck. Nothing worse than a septic system gone bad.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    That's great news! Not that $2500+ is chump change, but it could have been much more. I hope they can figure out a way to access the tank in the future without have to tear out the deck.
  7. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    The new lid certainly makes sense, but do you have any idea what he means about re-building the top of the tank? How large is the hole in the ground under your deck? Had the lid caved in or something?
    Ah. It just now struck me that you might only have one access hole in your existing lid and he is planning to remove it completely and replace it with an updated version. My son-in-law and I did that with an old and abandoned tank we revived here at home a couple of years ago.
  8. gundogblue
    Feb 15, 2008
    The tank is about 1000 gals, he said the top 1/8 part of the tank is deteriorating so he's gonna have to repair that and then put a new lid on, as well as installing a new pipe comming out of the septic tank, and possibly rebuilding the distrobution boxes, today Im gonna expose the distrobution boxes, it will save me a few bucks if I do that. As far as the deck is concerned , Im not going to put it back over the septic tank. Hopfully this nightmare will be over by this week-end. I feel that $2500.00 plus or minuse a little is a good price for all this work.
    Paul :)
  9. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    You almost lost me. It would help to reply to your original thread instead of making a new one.
    $2500 seems fair for that amount of work. Once you have the old system mapped out and know how to use the distribution boxes you can shut down an area that is "wet" and let it dry out for 6 months, then turn it back on again. It typically helps a system to alternate between sections of a field that way.
  10. gundogblue
    Feb 15, 2008
    Southern Man,
    Wow I never knew that, see the info you get on this site is worth it's wait in gold. I dug today but only found one distrobution box where the water was standing, and it don't look to healthy to me, I also found where the field tile "T's" out, three of those, and I found a place where there is a piece of field tile that acts as a stand, I asume it's for a clean out. So far only one field tile that I have found is broken, and everything past the distrobution box where the water was standing in my yard seems dry. The repair guy is comming out tomorrow to check out what I have done, with the septic tank uncoverd, and pumped out, and everything that I have dug, hopfully he will have a better picture of how to revive my old septic system, I'll keep you all informed.
    Paul
  11. Southern Man
    Jun 27, 2008
    North Carolina
    That's why some here call me a "disgrace to all engineers". ;)
  12. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Your only that some of the time....
  13. Southern Man
    Jun 27, 2008
    North Carolina
    Depends on how much corn mash I used up that day...
Similar Threads: Sick Septic
Plumbing Forum, Professional & DIY Advice Water Dead Ends (sickness)? Sep 26, 2008
Plumbing Forum, Professional & DIY Advice Plumbing sounds like a sick animal... Jan 14, 2008
Plumbing Forum, Professional & DIY Advice Older septic system runs fuller than it should; how to clear out sediment from lines? Dec 7, 2016
Plumbing Forum, Professional & DIY Advice Converting septic line cleanout (diagram\pic) for drain use Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Roots growing into septic tank Oct 16, 2016
