dirtmcgirt79
- Messages
- 3
- Reaction score
- 0
- Points
- 0
Ok, so my wife and I are remodeling a small bathroom on the first floor. We were all set to install a recessed medicine cabinet, so I cut the hole.. Only to find the sink drain pipe from the 2nd floor bathroom vanity running down in the middle of the hole.. I should have figured that was gonna happen.
So anyway.. the pipe is running between 2 2x6 studs.. I have to frame out an opening in the framing anyway.. Is there any chance that i can re-route the drainage line? If I start up high enough in the wall, put in a 45degree elbow and run it out past the hole, then down, and back over so that it'll line up with the 1st floor drain?? This is PVC pipe..
Or should I abandon this project and just hang a mirror instead?
