re routing electic plumbing for washer
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by domcal, Feb 11, 2007.
  1. domcal
    domcal New Member
    Feb 11, 2007
    Hi, does anyone know if it's possible to re rout existing plumbing for an electic washer? The plumbing works but the drain pipe is a simple black PCV pipe...the sewer/main drain is across the room and same level.
    The washer works but is in the middle of the basement that we're trying to remodel.
    Thanks,
    Domcal
  2. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    Yes, it's possible. Without being there, I can't say if it's probable.
  4. domcal
    domcal New Member
    Feb 11, 2007
    Hi thanks for responding. Could a plumbing move all the plumbing over to the new location of the washer? I figure that the drain pipe would have to stay but we'd have to have a long pipe extending from the washer to the drain which is about 15 ft... is this a bad idea or is there a better alternative? The other plumbing ( hot and cold-copper pipes) seem to be less of an issue?
    Domcal
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The only problem might be the drain. A drain must be sloped at least 1/4" per foot of length, and a washer drain needs to be 2" diameter, be trapped and vented. There's nothing wrong with ABS pipe (black) if that's what the rest of your drain system is. I'd strong urge you to hire a plumbing contractor for this job, there are too many pitfalls that you might encounter. You're correct that water plumbing and electrical connections will not be difficult to deal with.
  6. hj
    washer
    Is it possible to move the washer? Yes, of course it is. Is YOUR plan the best one? Probably not, and it might be the worst one, but someone has to look at it and decide the proper way to move it.
Similar Threads: routing electic
Plumbing Forum, Professional & DIY Advice Kitchen Drain Re-routing... Help please. Dec 11, 2016
Plumbing Forum, Professional & DIY Advice How to fix main water line leak issue-repipeing or rerouting pipes Oct 7, 2016
Plumbing Forum, Professional & DIY Advice Saniflo toilet pump: routing discharge pipe Aug 15, 2016
Plumbing Forum, Professional & DIY Advice Rerouting waste line...is this radius okay? Apr 6, 2016
Plumbing Forum, Professional & DIY Advice Dishwash Drain Routing Around Corner Feb 22, 2016
