Re-locating an Aerobic Septic Tank System or use system as-is?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pearlbluevtx, Feb 8, 2010.
  1. pearlbluevtx
    pearlbluevtx New Member
    Mar 25, 2009
    I'm wondering what the issues are in moving OR replacing an aerobic septic tank system.
    The location of my aerobic septic tank is right behind my house. I want to build a poolhouse/separate structure that is lower than my septic tank system.
    Are my options:
    (a) remove the existing (6 yrs old) aerobic septic tank, backfill holes left by septic tank
    (b) relocated a new aerobic septic system in the lower area & move plumbing lines to re-direct into that tank + be able to add new unattached poolhouse/building to drain into that line and/or drain into the new location septic tank?
    2) keep current septic tank location but somehow have a "pump" type of system to push the waste from the lower poolhouse up to the current septic tank location.
    I don't know what is most viable but trying to plan it out now by researching -- and I'm not a professional but going to seek professional advice once I do some homework & educate myself.
    The use of the poolhouse would have one or two sinks, shower & restroom.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    There may be other opinions on this, but I would relocate the septic and avoid the complications of a pumping system. Pumps fail, clog, and require servicing. I base my opinion on the frequent questions concerning problems brought to the forum by folks with basements requiring pumps.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    You need to contact your local board of health or who ever does the permitting for septic systems and talk to them about what you are thinking of doing...they will be the people who will ultimately decide if you can do what you propose and what you will have to do if in fact your able to.......
  5. pearlbluevtx
    Mar 25, 2009
    Thanks Gary & Cass. Yes, Cass - I thought I should do that ... hopefully it won't be too much of a hassle dealing with them!!
Similar Threads: Re-locating Aerobic
Plumbing Forum, Professional & DIY Advice Help with re-locating bathtub vent pipe Jul 8, 2016
Plumbing Forum, Professional & DIY Advice Re-locating toilet drain Jan 22, 2010
Plumbing Forum, Professional & DIY Advice Aerobic septic tank smells inside house Apr 18, 2011
