Re-Installing Same Bathtub
Discussion in 'Shower & Bathtub Forum & Blog' started by dankoos, Jul 14, 2009.
  1. dankoos
    dankoos New Member
    Jul 14, 2009
    Columbus, Ohio
    I have a deep tub that sits into a hole in a tub "deck". I wanted to replace the tile on the "floor" of the deck and also on the walls around the tub (there is not shower). Several tiles had broken. Once I got the old tile off, there was a bunch of mold on the roofing board that made up the tub deck..it was really soft as well. There were two layers of 3/4" board, so I just removed the first layer..bottom layer was fine. I am currently in the process of installing a new layer of decking.
    My question is two-fold for when re-installing the same tub (the tub itself was in fine condition).
    1. When re-connecting the water supply, can I transition from copper to plastic before connecting to the faucet? I had to cut away the original plumbing because the old fauced just didn't want to come off. Using a "roman style" faucet. I was introduced to those "shark bites" which I could use for this transition.
    2. When we took the tub out after disconnectinig the water supply lines, the drain from the tub, including the overflow, came right out of the P-trap that was sitting in the floor. So my tub is out but all the drain plumbing to the tub is still connected. The P-trap has threads on the top of it with a plastic nut already on it. Does the drain assembly from the tub just sit inside of that P-trap? What keeps it from leaking? Should I remove that nut from the P-trap? I have access to the drain from a hole in the wall, but it is tight...my plan was to just set the tub back into the deck..set the back of the tub in first and while a friend is sliding the front down I will reach in the hole and make sure the drain lines up w/ the P-trap.
    Thoughts?
  2. jadnashua
    Plastic may have a smaller ID, so you may lose some volume capacity.
    The nut compresses a tapered washer that makes the seal around the outside of the pipe. If it wasn't tightened enough, or has degenerated some from age, it may not have kept a good seal.
Similar Threads: Re-Installing Same
Shower & Bathtub Forum & Blog Water runs from handheld and wall shower same time Oct 23, 2016
Shower & Bathtub Forum & Blog Newbie : Miracle Method resurfaced my 1985 tub and now have same problem Jun 9, 2014
Shower & Bathtub Forum & Blog Shower and Bath Same Wall Mar 15, 2013
Shower & Bathtub Forum & Blog Kohler acrylic bathtubs- are they the same from HD vs. plumbing store? Jul 28, 2011
Shower & Bathtub Forum & Blog Design, connecting shower and washing machine drain to the same sewer pipe. Oct 17, 2010
