RE- Connecting 4†ABS to 4†steel, near tree roots.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lahabra, Aug 25, 2008.
  1. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    Tree roots have distorted a rubber hub and have grown into my sewer line.
    I have found and dug open the problem joint. Now I want to Replace the hub and wrap the joint with something to keep the roots away.
    I am Not willing to Internally re-line the pipes, replace the metal sewer main, Or kill the trees.
    How can I re-do this connection and prevent the tree roots from re-entering the sewer?
  2. Master Plumber 101
    Master Plumber 101 In the Trades
    Aug 11, 2008
    Wisconsin
    Can you use 4" fernco couplings. Cut the bad section out splice a new piece in between. Is no hub cast iron?
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Something like this would be good.
    [​IMG]
  5. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    That is what the previous plumber used. The tree roots were able to pry it open and move the rubber out of place.
    Are you suggesting that the coupling was not properly installed and that's why the roots destroyed it? And, if the new coupling dose not leak the roots will not be attracted?
    I am thinking of going over the top and doing a super repair. I am planning to:
    1. Rub toilet ring wax on the ends of the pipe to fill any imperfections.
    2. Install a 4†Fernco rubber coupling over the wax.
    3. Wrap the joint with copper wire to inhibit roots.
    4. Wrap with 20 mill tape to seal.
    5. Coat it with copper sulfate.
    6. Seal again with more 20 mill.
    7. Add 200 cooper clad pennies into the back fill dirt.
  6. jadnashua
    Roots seek water. If the thing wasn't tightened down properly OR if the ends weren't in line (distorting it) OR if the pipe wasn't clean when attached, there could be a leak. The tendrils are quite small, so any leak would leave enough space for it to grow in there.
  7. Redwood
    Dec 15, 2007
    Service Plumber
    If water is leaking out of the pipe roots will enter it.
  8. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    Sort of sounds like the mission bands were not the right ones for the job. That is why they make different bands for all types of materials and they should not be mixed.
  9. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Rubber Hub 4" Steel X 4" Abs Roots
    Forget All About All Those Copper Pennys And Wire Stuff And Wrapping With Mil. Tape
    All You Have To Do Is Install New Band Coupling And Take Some Rock Salt Pour Over And All Around Joint No Roots Will Grow Though Salt ! ! ! !
  10. Redwood
    Dec 15, 2007
    Service Plumber
    That should be good for the cast iron.:eek:
  11. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    Dose anyone like or dislike my idea of using toilet ring wax?
  12. MASTERPLUMB777
    Aug 6, 2007
    Texas
    4"abs X 4" Steel
    Important Note;
    Roots Grow THOUGH Wax Seals
  13. Redwood
    Dec 15, 2007
    Service Plumber
    It will probably help the mission coupling slide right off the pipe too!
  14. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    You cuold use what we call is a hot pour, hot melted tar over the joints.
    This is old school I know but it worked for many decades.
Similar Threads: Connecting 4â€
Plumbing Forum, Professional & DIY Advice Connecting PVC to ABS and Fernco for an adapter Apr 7, 2017
Plumbing Forum, Professional & DIY Advice Connecting L copper to M copper Mar 11, 2017
Plumbing Forum, Professional & DIY Advice Connecting new shower drain to existing tub drain Mar 5, 2017
Plumbing Forum, Professional & DIY Advice Connecting additional shower drain to an existing tub drain. Feb 28, 2017
Plumbing Forum, Professional & DIY Advice Weird thing with flushomatic toilet; tube connecting pipe to wall Aug 30, 2016
