Razor in toilet
Discussion in 'Toilet Forum discussions' started by adenwork2, Apr 15, 2007.
  1. adenwork2
    adenwork2 New Member
    Mar 12, 2005
    California
    Just finished removing a razor from a toilet. Loads of fun. Plastic disposable but had a larger than usual handle. Someone admitted dropping a razor so at least I had an idea what the problem was.
    Had to remove toilet. Was afraid to augur it because I did not want the razor to move farther into the house waste pipe. Razor got stuck in a 90 degree bend about 6 inches from the waste horn. Had to pull it with a coat hanger and grab it with very long narrow nose plier to break the handle. Was able to shake the razor in pieces out the waste horn. Happy to see that the old wax was in good shape, no leaks. Just remembered an old trick. Heat up the new wax slightly in the oven. Softens up and seals better.
    I was afraid I would need a new toilet because it took quite a long time to grab the razor and break it. Kept trying until succeeding because I have a 10" rough in. Not easy to find a 10" R.I. toilet immediately. Harder to find a good performer in 10" R.I.:)
Similar Threads: Razor toilet
Toilet Forum discussions Toilet Flange not Flat/Level Yesterday at 2:21 PM
Toilet Forum discussions How is the toilet made the difference between 1.28 and 1.60 GPF toilet? Saturday at 9:18 PM
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Saturday at 9:06 PM
Toilet Forum discussions Toilet leaks than stops Thursday at 9:59 AM
Toilet Forum discussions Baffled! Replacing existing same toilet does not fit!! Feb 15, 2017
