Rapid pressure loss
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Old man, Feb 8, 2009.
  1. Old man
    Old man New Member
    Feb 7, 2009
    Minnesota
    I have a submersible pump, a Well-X-Trol WX-202 pressure tank and a Square D 9013FSG 30/50 switch -all installed in 1987.
    Problems started last week when the water turned muddy with sediment and air spurting out of the faucets and the pump short cycling. I adjusted the Square D switch to reduce the pressure and the water cleaned up -the pump however continues to come on when no water is running (no leaky plumbing fixtures that we can see).
    It turned out that the pressure in the drained tank was only 5 psi. I added air to bring this up to 20 psi and adjusted so that the pump cuts in at 24 psi. Pressure builds slowly (2 minutes) until the pump cuts off at 36 psi. The pressure drops rapidly (10 seconds) accompanied by the sound of water running - and the pump kicks in again.
    Could the bladder in the tank be ruptured or maybe leaks in the well piping? How can you tell these apart plus what/where is a "check valve"?
    Any advice would be great.
    Thanks
    Thanks
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The only check valve that counts is the one on the submersible pump. Do you know what type of pipe you have between the house and the pump? Based on your description of what is happening, you probably have a leak in the drop pipe going down the well or the check valve on the pump is bad. It is also possible that the lateral pipe between the well and the home is leaking. This is even more likely if the ground has been frozen as a frost heave could damage the pipe.
    If you open the well cap, you might be able to hear it if the drop pipe is leaking. If it's the lateral and the well can produce enough water, sooner or later the water will start bubbling up out of the ground. In any case, these types of repairs are best left to a pro or someone that has the resources of one.
  4. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    It's a leak!
    Yep, you've got a leak somewhere between the pump and the tank. It could be a defective check valve at the pump but I doubt that!
  5. Old man
    Old man New Member
    Feb 7, 2009
    Minnesota
    Many thanks for replying
    Looks like one inch PVC pipe coming out of the basement floor. The ground (WI) has been frozen.
    The aluminium well cap seems sealed onto the well casing - is it ok to prise it off?
    Thanks again.
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    There should be set-screws or bolts around the outer diameter of the cap holding the cap on the casing. You might need to give it a whack or two if there is corrosion between the two.
    Most importantly, don't let anything fall into the well!
Similar Threads: Rapid pressure
Pumps and Tanks Well Forum & Blog. Water is life. Rapid pressure surges Oct 24, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pressure Switch violent/rapid clicking on/off Jul 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch cycles on/off very rapid on booster pump Oct 14, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch cycles on and off rapidly Sep 20, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch rapidly goes on and off at cut in and eventually burns out. Jun 10, 2013
