Rainsoft Q2 not drawing brine during cycle -- any suggestions?
JasonS
Bay City, Michigan
Hello!
Are there any participants in this forum who are knowledgeable about Rainsoft Q2 systems anymore?
I've replaced the O-rings on the piston and the system runs through a cycle in a mostly normal manner. The system fills the brine tank with water, but never draws water from the brine tank.
Currently the Tri-Guard is full after the cycle completes and the white ball remains pegged at the top of the Tri-Guard.
Here's what I've done:
* Replaced piston O-Rings
* Removed brine line that goes from Tri-Guard to tank and ensured it is clear and unobstructed
* Removed smaller line from Tri-Guard to valve and made sure it is unobstructed
* Confirmed that the little venturi washer is inserted into the Tri-Guard fitting that the line from the valve connects to
* Confirmed that the screen in between the Tri-Guard line and the valve is clear and unobstructed
* Ensured there is no debris blocking the bottom of the Tri-Guard copper line coming from the valve
* Confirmed that the poppet is installed between the Tri-Guard and the copper line from the valve
* Confirmed that the o-ring on the poppet is in good shape
I'm stumped as to why the unit is not drawing brine.
Thanks,
Jason
JasonS
Bay City, Michigan
Here is the diagram and parts list of the exact valve that I'm troubleshooting.
Jason
  • rainsoft-q2-valve-diagram.pdf
  • rainsoft-q2-valve-parts-list.pdf
Akpsdvan
Alaska
It might be time to look into replacing the system. I know of no parts for the system on the market and most likely even RainSoft does not have replacement parts.
Leonid Grossman
Cupertino, CA
Jason
Hi Jason,
Wonder if this was ever resolved, as I have the same system and troubleshooting a somewhat similar issue.
The system seems to work in two different cycles, using different amount of salt and drawing brine differently.
Most of the time, after the cycle when I run diagnostics * commands I see
~800 gallons of water used prior to regeneration
~4-5lbs of salt used for regeneration
the brine is drawn (salt in the tank is dry)
But on occasion, I see
~2400 gallons of water used prior to regeneration (about the same as the full capacity)
19lbs of salt used for regeneration
The brine is not fully drawn (there is water left in the tank)
the latter scenario is similar to what I see after the manual cycle.
if I run the phases manually, I can draw the brine - so it looks like the brine drawing cycle is just not long enough in the latter case...
