Rainsoft AQB Series E
Discussion in 'Water Softener Forum, Questions and Answers' started by Max1956, Jan 25, 2013.
  1. Max1956
    Max1956 New Member
    Jan 25, 2013
    Indiana
    My softener(rainsoft AQB series) had a power outage and my backup battery went low. I added a new battery, reset my computer with previous settings and tried to regenerate manually but nothing happened. I even set the current time to 5 minutes before generation time and waited for those five minutes. Nothing happened. My cams are not turning, What gives?
    Thanks
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    If your system is of the brass body, then most likely the main motor is gone.
    If your system is the plastic body that looks like the Fleck ProFlo or 5000 then the cam motor is gone.
  4. Max1956
    Max1956 New Member
    Jan 25, 2013
    Indiana
    Thanks, It is a brass body and after looking at it closer I found the motor is running but nothing turning but the shaft of the motor. The shear pin is not broken and the gear on the end of the motor shaft appears to have the gears still there(not sheared). Could something in the gear box be bad or does that happen very often?
    Thanks
  5. Akpsdvan
    Dec 29, 2009
    Alaska
    Sadly there are no parts for your system today.
    If the motor is turning but it is not getting the cams to turn then there is problem and with no parts other than what you might find used, it is time to replace the system.
Similar Threads: Rainsoft Series
Water Softener Forum, Questions and Answers Newbie with rainsoft system Dec 30, 2016
Water Softener Forum, Questions and Answers Rainsoft system leaking May 17, 2016
Water Softener Forum, Questions and Answers Newbie - Rainsoft equivalent alternative? Suggestions please. Mar 12, 2016
Water Softener Forum, Questions and Answers Replace Rainsoft Q2 water softener refill seat Mar 1, 2016
Water Softener Forum, Questions and Answers Rainsoft Q2 not drawing brine during cycle -- any suggestions? Oct 8, 2015
