Rainbird1800 sprinkler heads along sidewalk
Discussion in 'Irrigation / Sprinkler Forum' started by vaman, Jun 22, 2010.
  1. vaman
    vaman New Member
    Jul 15, 2009
    NJ
    Part of our irrigation system has a series of Rainbird 1800 spray heads that throw water across a sidewalk to hit some shrubs. The shrubs do get watered and I adjusted the AP heads so there is a direct spry but I there is a fair amount hitting the sidewalk. If I simply replace them with another 1800 that is taller would that work or am I asking for trouble? What do pros do when designing for such a situation?
  2. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    The only way I know to fix that problem is design the system so that sprinkler heads don't throw water over a sidewalk. That's against code in at least some areas, like mine.
    If you don't want to tunnel the water supply under the sidewalk, might consider switching to Hunter MP rotator heads. They are the size of spray heads, and in fact you can use your existing spray head body and just buy MP nozzles. They put out multiple streams at a time, and rotate slowly, so are able to spray water further than spray heads. They also put water down much slower than spray heads, so you get less runoff. You can see them on Hunter's web site.
  4. Fireguy97
    Fireguy97 Irrigation Contractor
    Mar 21, 2010
    Irrigation Contractor / Certified Backflow Assembl
    Kamloops, in Beautiful British Col
    You really didn't give us much to work with. A pro would at least have some dimensions to work with. How big is the area that you want watered? Is that area the one that's on the other side of the sidewalk? Do you have an existing zone on the other side of the sidewalk? Do you know if when they poured the sidewalk they placed a transport pipe to the boulevard?
    Is the sidewalk along the street, or leading up to your front door?
    Mick
  5. tomm
    tomm New Member
    Feb 21, 2008
    So the heads throw across the sidewalk? and you want to prevent the sidewalk from getting wet?
    I want to buy some gold at the price it was selling for some 5 or 6 years ago. :)
Similar Threads: Rainbird1800 sprinkler
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Sunday at 3:14 PM
Irrigation / Sprinkler Forum Flow required to properly blow out sprinkler system Oct 22, 2016
Irrigation / Sprinkler Forum Sprinkler head problem Sep 18, 2016
Irrigation / Sprinkler Forum Inground sprinkler system SPLITTER? Sep 8, 2016
Irrigation / Sprinkler Forum Sprinkler Issue Jul 2, 2016
