Rainbird Troubleshoot
Discussion in 'Irrigation / Sprinkler Forum' started by firstcut, Apr 3, 2006.
  1. firstcut
    firstcut New Member
    Mar 31, 2006
    New to using Irr.system.
    The Rainbird has 3 zones which cycle on, however one zone does not come on at all, it goes dormant for the cycle, then next zone comes on as expected. Was working fine last fall.
    What steps to troubleshoot?
  2. hj
    There is a problem with the valve or wiring to it. There are too many possible causes to list them and it is easier to just test the valve and then fix that problem.
  4. jimbo
    jimbo Plumber
    First check the valve. Almost all have a screwdriver or thumbturn screw which will cause the valve to turn on. If this works, the problem is electrical, either a bad solenoid or bad wiring connection .
  5. PEW
    PEW DIY Senior Member
    If they are Rainbird valves, you can turn the solenoid about half a turn to manually turn on the valve. As stated above that will give you an indication as to where the problem is.
Similar Threads: Rainbird Troubleshoot
Irrigation / Sprinkler Forum Looking for old style RainBird valve solenoid - round with vertical ribs Feb 23, 2016
Irrigation / Sprinkler Forum Rainbird 32SA Question Sep 9, 2015
Irrigation / Sprinkler Forum Rainbird ESP-me Start Time issue Jun 24, 2015
Irrigation / Sprinkler Forum progams A and B rainbird ESP-Me Controller Timer Jun 11, 2015
Irrigation / Sprinkler Forum Rainbird ESP-M Controller Problem??? Sep 14, 2013
