Rainbird solenoid help please, it says "manual 1/4 turn On/Off
Discussion in 'Irrigation / Sprinkler Forum' started by jasper7821, Oct 18, 2012.
  1. jasper7821
    jasper7821 New Member
    Sep 24, 2012
    Arizona
    I think my solenoid is bad, I unscrewed and took it off of the valve.
    I turned on the controller and walked back to the valve and just heard it buzzing.
    I tried to clean the blue screen and it just fell apart in my hand.
    I'm getting a new solenoid but what does the 1/4 manual on/off mean.
    Don't I just screw it in all the way until it stops and wire it up.
    Or does unscrewing it 1/4 turn turn it on somehow.
    I tapped it on the ground and the round metal piece popped off, I then turned on the controller again and walked back and the metal rod was lying on the ground. Does putting power to it push the rod out?
    I also think my Hunter EC controller is bad. I was trying to program it and it was 8:58pm and the timer said 8:98. And when trying to set the days it should show 1-7 but it was only showing 1-6. Any ideas ?
    I tried to reset but the screen went blank when I pushed reset but everything came back to the same when I let go of the button. It kept the same programs.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    What you do when you turn the solenoid counter clockwise is to manually open the valve. This is especially useful when blowing the lines with air for winterizing or if you are working on one zone and want the water to run without having to punch the buttons on the controller. Turn it back clockwise until it stops, and the valve is ready to electrically operate. You had it pretty well figured out.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Many Rainbird valves have no manual on "switch", instead you just unscrew the solenoid 1/4 turn to do manual on.
Similar Threads: Rainbird solenoid
Irrigation / Sprinkler Forum Looking for old style RainBird valve solenoid - round with vertical ribs Feb 23, 2016
Irrigation / Sprinkler Forum Rainbird 32SA Question Sep 9, 2015
Irrigation / Sprinkler Forum Rainbird ESP-me Start Time issue Jun 24, 2015
Irrigation / Sprinkler Forum progams A and B rainbird ESP-Me Controller Timer Jun 11, 2015
Irrigation / Sprinkler Forum Rainbird ESP-M Controller Problem??? Sep 14, 2013
