rain shower head height...
Discussion in 'Shower & Bathtub Forum & Blog' started by chris fox, May 19, 2007.
  1. chris fox
    chris fox Member
    May 9, 2007
    near phoenix AZ
    Were using a rain style shower head with a 16" arm and need to know a good height. I know the nominal height for a shower head is 72" but also know its up to the user based on a search in this forum but that thread was related to a regular style shower head.
    I never used a rain style head before, is there a recommended height to get the best experience using this style?
    I am 6'2" and wife is 5'5" and thinking of 84"
    thanks
  2. jadnashua
    I'd want it high enough so if I was lathering up my hair, I wouldn't have a chance of knocking the thing. 10" should be enough.
  4. chris fox
    chris fox Member
    May 9, 2007
    near phoenix AZ
    assuming 10" inches over my height (6'2").
    thanks
  5. jadnashua
    YEs, that's what I was thinking...
  6. AlwaysInHotWater
    AlwaysInHotWater New Member
    Mar 27, 2007
    California
    Another option is to position the outlet at a more normal height and use a riser-extension arm instead of a straight arm. This allows you to switch back to a standard shower arm and head at a later date without it being out of reach for some users.
    Look here towards the bottom of the page for the type of arm you might want to consider: http://www.neatitems.com/shower_arms.htm
Similar Threads: rain shower
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Saturday at 4:17 PM
Shower & Bathtub Forum & Blog Delta rain can shower head install Feb 19, 2017
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
