Rain Bird drip line
Discussion in 'Irrigation / Sprinkler Forum' started by teamo, Aug 7, 2011.
  1. teamo
    teamo Member
    Jun 26, 2005
    Massachusetts
    I recently added a few zones of Rain Bird drip line to some new flower beds. I think from what I've read that the drip line should be limited to no more than 200 feet on a zone. I brought 1 inch line to the start of the bed and reduced down to the 1/2 inch for the drip line. I ran about 130 feet of drip line from there. The line runs to the end of the bed and is capped. I have another flower bed that is about 35 feet away from the end. Right now that flower bed is getting water from a small lawn strip that has spray heads. It is working okay but I like to have all of my flower zones separate so I can set different times/duration on those zones. I was wondering if I could use another fitting at the end of the drip line and convert back to the 1 inch line and bury that the 35 feet to the other flower bed. From there I would add another section of drip line to the 1 inch line. The run for the new bed will be about 50 feet so the total amount of drip line will still be about 180 feet. Would this work or would the changing over to the 1 inch at the end cause pressure/volume problems.
  2. mike1059
    mike1059 irrigation tech.
    Jun 6, 2011
    irrigation tech. for a landscape company
    Portland, OR
    I will assume that you are using 1/2" line with built-in pressure regulated emitters. In that case I see no problem with your plan.
  4. teamo
    teamo Member
    Jun 26, 2005
    Massachusetts
    Yes it is the 1/2 inch brown rain bird drip line. Not sure of the model number of the line I will have to read it when I get home. The emitters have 12" spacing between them. I used a pressure regulator/filter coming off of the 1" valve at the valve manifold which drops the pressure down to about 30 pounds.
  5. mike1059
    Jun 6, 2011
    Portland, OR
    I just did a quick calculation and at the maximum flow rate for that type of drip line, 180' will give you a flow thru your valve of 2.7 to 3.0 gpm so I still see no problems with your plan.
  6. teamo
    teamo Member
    Jun 26, 2005
    Massachusetts
    Thanks for the help.
Similar Threads: Rain Bird
Irrigation / Sprinkler Forum Rain Bird ESP-6TM Program B worked yesterday not today... May 8, 2016
Irrigation / Sprinkler Forum Looking for old style RainBird valve solenoid - round with vertical ribs Feb 23, 2016
Irrigation / Sprinkler Forum Rainbird 32SA Question Sep 9, 2015
Irrigation / Sprinkler Forum Rainbird ESP-me Start Time issue Jun 24, 2015
Irrigation / Sprinkler Forum ESP-ME Rain Bird controller question Jun 20, 2015
