radiators only bleeding air, no water
Discussion in 'HVAC Heating & Cooling' started by plumbbob, Nov 19, 2007.
  1. plumbbob
    plumbbob New Member
    Nov 4, 2004
    Hi - i've been noticing our (hot water) radiators have been in need of bleeding (cold at the top, hot at bottom) so I went ahead and did it yesterday. I shut off the system, turned off the fill line and bled the radiators. I started on the downstairs units and they bled air to water just fine. Then I went upstairs and only got air...loads of it. Almost every radiator on the 2nd floor bled air for about 15 seconds, but water never came. I wasn't sure what was going on, so I decided to turn everything back on and see if it would refill properly.
    Now that it's back on, I feel some warmth in the radiators upstairs, but they are generally pretty cold. My wife is complaining that it's freezing in the bedrooms (it is) so I need to figure out why I can't get the upstairs to bleed properly.
    Did I screw up by starting downstairs? Should I drain and then refill the whole system?
    I could really use some help here. Thanks, Matt
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    You need water flowing in, in order to push the air out. You do have a working pressure reducer feeding this system, right?
  4. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    The fill line needs to be left on.
  5. plumbbob
    plumbbob New Member
    Nov 4, 2004
    ok, fill line is open...still only getting air
    So I shut off the system, left the fill line open and still only get air coming out (upstairs).
    I looked at the fill line and there is a B&G reducing valve (model 110192) with a 'flip lever' on the top. It seems that water only enters the system when I flip the lever up.
    Inbound water pressure is about 40 PSI, and I have a booster that takes it to 65 PSI.
    Is that valve working normally?
    Thanks, Matt
Similar Threads: radiators bleeding
HVAC Heating & Cooling Bleeding radiators Jan 26, 2016
HVAC Heating & Cooling radiators still only bleeding air...ideas? Nov 19, 2007
HVAC Heating & Cooling Convert steam radiators from oil to gas May 7, 2013
HVAC Heating & Cooling Column Radiators and Baseboard radiators Jan 8, 2010
HVAC Heating & Cooling Install Upstairs Radiators, do I need valves? Dec 29, 2009
