Radiator Valves
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Ed from chicago, Oct 30, 2005.
  1. Ed from chicago
    Ed from chicago Member
    Apr 25, 2005
    Chicago
    Hi all!
    Can you please discribe the difference between a steam radiator valve and one that controls the flow in a a hot water system. And whether they are interchangeable.
    Ed
  2. hj
    vqlves
    A steam valve is a globe valve with a fiber disc washer and it closes by turning the handle until it stops. It turns off the steam completely or you would have condensation problems in the radiator. A hot water valve turns off by rotating a cylinder to close the opening. The cylinder has a small hole in it to allow a minimal amount of water to flow through the radiator. A steam valve can be used for hot water, but a hot water valve cannot be used for steam.
Similar Threads: Radiator Valves
Plumbing Forum, Professional & DIY Advice TRV Radiator Valves Oct 27, 2011
Plumbing Forum, Professional & DIY Advice Can I fix steam radiator shut off valves or do I have to replace Oct 14, 2007
Plumbing Forum, Professional & DIY Advice Hot water radiator valves--does location matter? Mar 17, 2007
Plumbing Forum, Professional & DIY Advice Radiator valves Sep 19, 2004
Plumbing Forum, Professional & DIY Advice Towel Rail Radiator Installed Sideways Jan 21, 2017
