The issue may not be efficiency (of energy use), but of its ability to actually push the heated water through the long loops. If it can't push much water, it will quickly reach its setpoint and shut off. It might then cycle frequently and shorten its life without actually heating much. Two issues here: available input BTU, and the effective output BTU to the building. 1000' loops won't be very efficient at transferring heat, nor will it lend itself to evenly distributing that heat as whatever is input at the beginning, cools the water, and there's not much left as you run down its length. You cannot start with super hot water, as that can be dangerous and uncomfortable and damage the floor as well.
