Ah, that vintage Solo had a huge jump from the -60 to the -175, with nothing in-between. The -60 is clearly not enough, therefore... The current vintages all have a -110, which would be a more appropriate size, therefore the confusion. Mind you, they probably sell a lot more -110s than -60s, and the -60 is more than enough boiler for 19 out of 20 homes out there.
Looking at the plumbing it appears to be pumped direct. On page 4 of the manual they caution that it should always be plumbed primary/secondary if there is potential for seeing water temps below 46F, which it almost surely would in the snow-melting zone.
If you valve-isolate the expansion tank then relive the pressure on the water side, you can then properly pre-charge the tank using an air-pressure gauge. You'd then open all of the isolating valves anywhere in the system, hook up a hose connected to your potable water system to ANY of the system valves with hose fittings, and fill until the system pressure is 15-18psi, assuming the highest point on the system is 30-35' above where your gauge is located. Only then would you fire the system back up. You appear to have multiple options for fill-ports and temporary pressure gauges. The bronze capped boiler drain taps with ball-valves on both sides of the bottom of the boiler appear to be hose-thread, as well as the cluster around the expansion tank.
