Radiant heat pump sizing
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Raucina, Jan 19, 2007.
  1. Raucina
    Raucina New Member
    Jul 30, 2006
    toiletvalveguy
    Can anyone advise on feet of head required to push water through PEX [poly] tubing, 1/2" ?
    I want about 1 to 3 gallons per minute through EACH of [4] 300 foot loops in a slab. There are 4 ball valves that can isolate each zone, so at times only one or two zones are open. When all 4 zones [1200'] are open flow as low as 1 gpm or less should be alright.
    I am looking at Taco and Grundfos pumps in Grainger [open loop - need bronze or SS head]
    Maybe the three speed motor from Grundfos to allow for adjustment?
    Simplified question; How many feet of head required to push water at 2GPM throu 100' of PEX?
    I have done several systems before, but would like to not simply guess at the unit or opt for a high head and throttle the pump. These are impedance protected so overload is not an issue.
    Thanks for any math in advance!
Similar Threads: Radiant heat
Pumps and Tanks Well Forum & Blog. Water is life. Radiant Heat, Pex Supplier, Parts, Outdoor Boiler Insulated Line Aug 17, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Well pump constante pump solar heater coupled to house and garden design Jan 26, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump for geothermal heating in primary Jan 8, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Water Heater Drain Pans Aug 15, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Submersible Well Pump Overheating? Jul 19, 2012
