Looking for folks' thoughts on this.
I had the boiler on my radiant heat system stop working the other day and when I investigated quickly figure out why--four of the main feeder lines had air in them!
A quick call to and visit by a local radiant heat specialist resulted in his opinion that the guys who installed the system hadn't properly bled it out, and so over time the air collected and coalesced and then one day *boom*....pressure was too low for the system to operate properly. He filled it all up, we restarted the system and things seemed goodly.
However, after a couple of days I noticed that my energy draw (I'm off-grid) was still much higher than it had been prior to all this fun. I expected higher usage while the system got the house back up to temperature but it was at that according to all of the thermostats and usage was still higher than I would have expected. As I was poking around the installation I realized that the circulation pump (a Grundfos) is VERY hot. The fluid (glycol) is set to 130[SUP]o[/SUP] F and I can easily put my hand on the copper manifold coming out of the boiler, but that pump is way hot--you can't keep you hand on it at all.
My thinking is that the pump may have run dry for a day or two before I noticed the overall problem, and that's why it's running hot and using energy--it has unfortunately been damaged.
What do folks think? I can honestly note that I don't ever recall laying my hands on that pump before all this, but I'm sure I must have and would have remembered it being this hot....so I'm afraid damage seems my most likely situation.
Steve
From the High, Snowy Mountains of Colorado
Steve
