Radiant Floor HEating
Discussion in 'HVAC Heating & Cooling' started by R3Improvements, Sep 21, 2009.
  1. R3Improvements
    R3Improvements DIY Junior Member
    Sep 20, 2009
    Toledo, Ohio
    Is there an inexpensive radiant floor heating mat I can put under tile? Is there a brand that costs less than the others but is still good quality?
  2. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    I don't know, but what I would like to see is a decent insulating system under tile to give it a few R units (carpet equivalent) without building up the floor several inches off the concrete. Every time I mention it at tile shops I get directed to radiant heating instead. Rather than add heat, I want to somewhat insulate the floor from the frigid winter perimeter concrete. Seems like a very common problem, but nobody is addressing it.
  4. PEW
    PEW DIY Senior Member
    I have used Warmly Yours over Wedi board on many installations. Regardless of what product you use, by all means use a floor sensing thermostat, not an air sensing one.
  5. jadnashua
    Cable systems tend to be less expensive than mats because they take more on-site work. If you aren't paying labor, then that may save you some money doing it yourself. Check out www.johnbridge.com for some ideas. INsluation on the floor helps, and under the slab even more (but that can't practically be retrofitted). If you have sufficient height, you can add some fairly thick insulation, bu tthat often means resetting or rebuilding the steps, or you create a trip hazard on that (first) last step. If you have a walk-out basement, that may also mean redoing the door(s). The only tileable insulating foam that can be used under tile I know of is Wedi. EasyMat has some insulating features, too, and it can be tiled on, too. If there are any moisture issues, I think Wedi would be better...not sure about moisture absorbtion with EasyMat (might be okay). Either of those can be purchased in various thicknesses, and the thicker, the more insulation (I think Wedi has more R/inch than EasyMat).
Similar Threads: Radiant Floor
HVAC Heating & Cooling Radiant Floor Heat in Bathroom and other ramblings... Jan 7, 2017
HVAC Heating & Cooling In floor Radiant heat not working (under concrete slab) Jan 3, 2017
HVAC Heating & Cooling Floor radiant zones normally open or normally closed Jan 5, 2016
HVAC Heating & Cooling Floor joist radiant heat system Jul 13, 2014
HVAC Heating & Cooling Hydronic radiant floor help please Jul 7, 2014
