Quieter shower valve & head?
Discussion in 'Shower & Bathtub Forum & Blog' started by pagebri, Nov 5, 2005.
  1. pagebri
    pagebri New Member
    Nov 5, 2005
    Can anyone recommend a shower valve and/or valve & head combination which is much quieter than most? I have a Moen pressure balancing valve, and a off-brand "motion massage" head. This combination is too loud - it results in unbearable levels of high-frequency noise when the valve is anywhere in it's range but full cold or full hot. I'm guessing that the mixing valve introduces too much turbulence and/or cavitation. I'm hoping to find a better designed valve and install it without the need to re-tile.
  2. jeffreyhel
    jeffreyhel New Member
    Nov 4, 2005
    without retiling I would suggest Delta Monitor and check the water restrictor and screen of the shower head for debris and or restriction.
    If you want to retile I like Grohe valves.
  4. pagebri
    pagebri New Member
    Nov 5, 2005
    Problem fixed
    Removing the flow restrictor eliminated 80% of the noise. The designers could have done a lot better than a washer with a square-shouldered hole which seems to act like a whistle.
Similar Threads: Quieter shower
Shower & Bathtub Forum & Blog Symmons / Temptrol valve, Water comes out of tub spigot when shower is on - New diverter did not fix Yesterday at 7:02 PM
Shower & Bathtub Forum & Blog Do all neo-angle showers have the same relative dimensions? Yesterday at 8:46 AM
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Saturday at 4:17 PM
Shower & Bathtub Forum & Blog Old delta shower valve not working Saturday at 6:30 AM
Shower & Bathtub Forum & Blog Lustrolite shower wall covering Feb 20, 2017
