Quick trap prime line question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by grahamW, Jun 14, 2012.
  1. grahamW
    grahamW Member
    Jan 26, 2012
    Ontario, Canada
    I'm running a primer line from my laundry sink to a p-trap in my basement floor slab and I have a quick question: Is there a preferred placement for this line and should I run a 2nd (backup?) line in case one is damaged? I assume I can just place it in with the concrete but I thought I would check.
  2. hj
    In that case, why not install 3 or 4 in case the second one is damaged also. There is NO REASON why the first one should be damaged, in the first place. How, or where, are you getting the water to feed the trap primer?
  4. Terry
    Aug 17, 2004
    The fitting we use for the trap primer place the pipe down farther from the top of the slab.
    We don't wind up pouring the pipe in the concrete, but below the concrete in the dirt. It's a nice looking drawing, but not real accurate.
  5. hj
    IF you use a floor drain with a trap primer tap, it will be in the concrete floor.
  6. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    In s.f. We do a lot of these
    Every old house has a floor drain in the garage. So on major remodels We have to add a trap primer. All in copper. We buy a new tapped trap .
    It's all cast iron in the city. ditch the plastic tube,bad idea !
Similar Threads: Quick trap
Plumbing Forum, Professional & DIY Advice Shower p-trap going dry quickly Mar 24, 2014
Plumbing Forum, Professional & DIY Advice Quick kitchen sink drain and vent question Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Electric Water heater runs out quickly Oct 1, 2016
Plumbing Forum, Professional & DIY Advice Hot water comes quickly but recirculating pump is off? Jun 15, 2016
Plumbing Forum, Professional & DIY Advice Quick vent question (near main stack) Mar 26, 2016
